Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. #11
    Join Date
    Apr 2002
    Posts
    209
    Clarksburg, Pa(Between Indiana and Saltsburg Pa)
    Cub Cadet 7272,Farmall 544
    Default Re: Cub Cadet Snowblower - Converting Power Chute to Manual Chute
    Wow....so happy I found this thread. I have a Cub cadet 826 with this same motor. My motor went bad 2 years ago and when I found out CC's price for a new I decided I would just have to live with it. For the last two years I have been strtegically blowing snow since the chute always pointed the same direction lol. Ordered the replacement motor through my local Napa for $40...should be in tomorrow.
    Thanks!
  2. #12
    Join Date
    Apr 2002
    Posts
    209
    Well, bought the motor from Napa for $30 after core turn in. I had to tap the holes in the new motor as they were smooth bore.....5/16x18 threads........also had to grind off a fin on the case that was in the way, maybe 1/4" max...just used a floor mounted shop grinder. Electrical plug was identical and required no modifications. Took about 1/2 hour from start to finish and the chute is back in service! Thanks to everyone for the replacement part number for the motor! Sure beats the $250 Cub cadet quoted me just for the motor itself!
  3. #13
    New Member
    Join Date
    Mar 2010
    Posts
    1
    MD
    John deer 376
    Thanks, I ordered the motor and with a little grinding had it on in a half hour. The connection matched perfectly. It now works better than it ever did.
  4. #14
    New Member
    Join Date
    Oct 2010
    Posts
    7
    Cub Cadet 8264X4 Snowblower
    When you state grind off fin, is that the fins near one of the bolt holes? It appears to me I would need to grind them off so it could get but that chute stop on the bracket. Is this correct. Oh, thanks for the bolt hole tap spec.
    AWK
  5. #15
    New Member
    Join Date
    Oct 2010
    Posts
    7
    I finished it. I had to grind of the fin that makes contact with the metal chute stop on the bracket. Tapped the 5/16 x18 thread into the gear housing on the motor (came with smooth bore bolt holes). Fits well. Now I have a electrical problem. I think I have a bad contact from corrosion.
    AWK
  6. #16
    New Member
    Join Date
    Oct 2010
    Posts
    7
    Thought this would help;
    Message - TractorByNet.com Photo Gallery
  7. #17
    New Member
    Join Date
    Feb 2011
    Posts
    1
    I know this is a old thread that strayed off topic but I just want to say thank you to those who commented as it help me save some $$$ and I now have a Cub Cadet 826 SWE snowthrower with a new electric chute motor with minimal modification that can be done with a hacksaw, hand file and tap.
    Even if one purchased the basic tools, he would still be under the cost of a dealer priced motor. Well done guys! Got my Dorman 742-119 from Autozone for about $50.00 though you can get it elsewhere for less if you'd like to wait a few days. I decided to take advantage of a clearing in the weather and get this done. And it worked great!
    Attached Thumbnails Attached Thumbnails Cub Cadet Snowblower - Converting Power Chute to Manual Chute-cadet1-jpg   Cub Cadet Snowblower - Converting Power Chute to Manual Chute-cadet2-jpg   Cub Cadet Snowblower - Converting Power Chute to Manual Chute-cadet3-jpg
  8. #18
    New Member
    Join Date
    Feb 2011
    Posts
    1
    WISCONSIN
    Cub Cadet 826 SWE
    I HAVE A Cub Cadet 826 SWE SNO THROWER Where do i get a motor to replace the burned out one for the chute?? With out spending a arm and a leg like CC wants for a new replacement motor??
  9. #19
    Elite Member Don87's Avatar
    Join Date
    May 2010
    Posts
    4,226
    SW Pa.
    Massey Ferguson GC2400
    Quote Originally Posted by FROSTY1 View Post
    Maybe check the post just above yours.
    Don
    MF GC2400, FEL, 60in.MMM, 5ft. Cultivator, Single Bottom Plow, Bush Hog RTC48 tiller, MF 2360 front mount snowblower, 5ft backblade. BXpanded Piranha toothbar.
  10. #20
    New Member
    Join Date
    Nov 2012
    Posts
    1
    Doylestown, PA
    Cub Cadet
    I unfortunately didn't try this. Last January mine went out and I ordered the OEM motor from M & D Mower. I installed it and it worked but we didn't get anymore snow and it sat until yesterday. When I went out to use it again, it was locked up. I called them and they only have a 90 day warranty. They guy at MTD (Bill) was not concerned at all that I paid $250 for it and didn't use it since we didn't have any snow. He just said they have a 90 day warranty and I was out of luck (not very friendly either). They guy at M & D tried to get it under warranty but MTD said no. So now I ordered the door motor for $45. I learned my lesson. I could buy 5 of them at $45 for the one OEM part I bought. I will post an update when this comes in. Thanks MTD for taking my $250 and giving me defective merchandise.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
