Results 1 to 7 of 7
  1. #1
    Member
    Join Date
    May 2006
    Posts
    46
    Barnhart, Missouri
    Ford-1100- New Holland 1720 - JD-345- JD-425- Cub Cadet- 1863
    Default 1863 Cub Cadet
    Does anyone have a lead as to where I can get a replacement Kohler CH-18 engine? Or has anyone had one of these apart for overhaul? I have been having starting problems for sometime and I need to do something about it. It acts like it's out of time while cranking but when it finally starts it runs pretty good. Any help would appriiciated.
  2. #2
    Platinum Member OldMachinist's Avatar
    Join Date
    May 2006
    Posts
    638
    Southwest Illinois
    Default Re: 1863 Cub Cadet
    Can't really say whats causing your problem except the normal suspects(points, plug, fuel, partly sheared flywheel key) but here a link to the service manual for it.
    http://www.kohlerengines.com/common/.../tp_2428_b.pdf
    You can get a new CH18 engine here Tulsa Engine Warehouse www.tulsaenginewarehouse.com tewarehouse.com webstore new site for www.smallenginebusiness.com but at around $1350 I'd make sure its not something I could fix first.
    2006 Cub Cadet Z-Force50
    Agco Allis 1616H
    1974 SearsGT18 with 3 point,48"deck,Haban sickle mower and front dozer blade
    2000 Bobcat 453F with steel tracks
    1954 Ford860 with front end loader, 5' brushhog
    1952 Allis Chalmers CA with Woods L59 mower
    1947 Case SC
    1998 Honda ACTY 4WD mini truck
    And too many other small engine tools to list
  3. #3
    Member
    Join Date
    May 2006
    Posts
    46
    Barnhart, Missouri
    Thanks for your reply. I'm in the process of removing the engine from the tractor. I want to check the air gap on the coil pack and also the flywheel key. Don't know yet if I want to pull the heads yet. I ran a compression check and it read 60 on the first hit then went up to 150 on both cylinders. A friend thought I might have some valve trouble. It has hydraulic lifters so there is no adjustment there.
  4. #4
    Platinum Member OhioGuy's Avatar
    Join Date
    Jul 2003
    Posts
    587
    Northeast Ohio
    Ford 1220, Case 245, Cub 1872, Cub 2284
    Hi Bob,
    I believe the earlier Kohler Magnums had a compression relief valve.
    I've replaced 2 ignition modules on the Magnum series, not sure how the Magnum differs from the Command with that Magneto module.
    Curt
    Ford 1220 FEL, Backhoe, Boosh hog, Core Aerator, Finish mower, Boxblade, 3 PT boom sprayer, Tiller, Case 245, Cubs 1872-2284.
  5. #5
    Member
    Join Date
    Mar 2004
    Posts
    41
    Central Washington
    Kubota BX22
    I have a NIB Kohler Command 22HP vertical shaft I received as a warranty replacement from Sears but sold the tractor before getting around to installing it. I've never even opened the box.
    No idea if your tractor uses the horizontal or vertical configuration, but if this would help, I'd sell it reasonably, as it's no use to me now. (went kubota diesel...) Was only in the Cub forum because I had a Yanmar a long time ago and saw some of the new Yanmar Cubs at a local dealer and got curious. Let me know, I'm Dave
  6. #6
    New Member
    Join Date
    May 2008
    Posts
    18
    Quote Originally Posted by leftybob View Post
    Small Engine Warehouse for a replacement. 800-321-6725 Have your serial and model # off the Engine and they can duplicated it . I plan on doing that to my 1863. Have put about 200 hrs on mine with a broken ring and getting to the point of having to pull the plugs and cleaning them to get at least 30 min more use out of it!LOL Bought it new and it has 2700 hrs on it. Poneykeg said that..
  7. #7
    Member
    Join Date
    May 2006
    Posts
    46
    Barnhart, Missouri
    I called the Tulsa Engine Warehouse and they got me info on the right model I needed to replace my old engine. They quoted me a price of $1437 plus shipping. I asked where do you ship from? Since I live near ST. Louis they said there is a supplyer in Arnold MO. I know right where that is and I have a friend that works there. So I got a exact replacement engine for $1147 tax and all. It was still a chore installing it getting the driveshaft in place but it's up and running now. All that was missing fron the engine was the muffler. The Cadet dealer wanted $225 for a new muffler so I put my old one back on whick was in good shape. The warehouse had a new muffler for $80 that fit the engine but not the tractor and it was too much modifying to make it fit. I may someday repair the old engine or sell it as is. It did run it was just getting too hard to start.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
