Results 1 to 6 of 6
  1. #1
    Gold Member
    Join Date
    Aug 2008
    Posts
    373
    Darlington, SC
    1957 Ferguson 35, 1977? Yanmar 2200, 1963 Cub Cadet Original
    Default 1963 "Original" Cub Cadet
    I have a '63 Original that the governor does not work on. It never has since I bought it. It cranks and runs good but no governor advance when you start uphill or get in a heavier pull. Can anyone point me in the right direction to rebuild the governor and get it to working correctly? I am pretty mechanically inclined but have no knowledge or experience with this. All info is appreciated.
  2. #2
    Gold Member
    Join Date
    Aug 2008
    Posts
    373
    Darlington, SC
    Default Re: 1963 "Original" Cub Cadet
    More info:
    It has a 7 HP Kohler horizontal shaft engine in case someone that is familiar with the Kohler but not the Cub Cadet application. The throttle cable runs to the governor where it goes into the side of the engine and the lever has a rod linkage that connects carb to governor arm.
  3. #3
    Join Date
    Jul 2005
    Posts
    1,924
    NH seacoast & Coos County
    Kioti DK45S
  4. #4
    Platinum Member Mighty Dodge's Avatar
    Join Date
    Jan 2007
    Posts
    517
    The Hereford Zone, MD
    JD 4200
    Here's a link to Kohler tech manuals for the k series.
    Service & Owners Manuals - Service & Support - Kohler Engines
    M.D.
    2001 JD 4200, 420 loader, HF Quick Hitch, bucket boom, back blade, boom pole, forks, carry-all, moldboard plow, middle buster, receiver hitch, post hole digger.
    My Pics
    http://www.tractorbynet.com/photos/s...0/ppuser/33421
  5. #5
    Gold Member BrierPatch's Avatar
    Join Date
    Aug 2008
    Posts
    352
    West Central Indiana
    Kubota B2620 364 FEL, BH65, 60" MMM
    It has been a long time since I set the governer on my 123. If I remember correctly the governer is a gear driven centrifugal weight off the crank inside the crankcase. I thought it was broken, but when I fixed the stuck valve (it had been setting for quit some time) I found that it was just not adjusted correctly. There was no adjustment inside the engine just on the outside. There is a shaft that sticks out that an arm is attached to. I believe it had a straight blade slot cut into the end of the shaft. The arm has a clamping bolt and nut and I believe it had slipped on the shaft. I don't remember the exact way to set it, but I am pretty sure I was able to just fiddle with it and get to work. You can kinda tell which way the shaft should rotate to pull the springs and stuff back from the throttle. I am not sure if there is a way to tell if the centrifugal weight and gear mechanism is okay without pulling the engine out.
    Good Luck, Hope this helps
    Jeff
    '08 B2620 364 FEL, BH65, and 60" MMM
    '86 B7200 HST, 4WD, 60" MMM w/834hrs sold 4-11-09
    IH 3616 industrial backhoe (hydrostat) currently for sale
    IH cub cadet 1450 sold 4-15-15
    IH cub cadet 123
  6. #6
    Platinum Member OhioGuy's Avatar
    Join Date
    Jul 2003
    Posts
    587
    Northeast Ohio
    Ford 1220, Case 245, Cub 1872, Cub 2284
    I think you can determine if the governor is working by just looking at the shaft and raising the throttle. I'll bet more times than not, it's an adjustment issue.
    The manual is availalable online, I'd bet the procedure to adjust is in there.
    Good Luck,
    Curt
    Ford 1220 FEL, Backhoe, Boosh hog, Core Aerator, Finish mower, Boxblade, 3 PT boom sprayer, Tiller, Case 245, Cubs 1872-2284.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
