Results 1 to 4 of 4
  1. #1
    Join Date
    Apr 2009
    Posts
    50
    Fenton, MI
    1995 CC 1864 Hydro
    Default 3-Point Hitch & PTO for CC 1864
    Anyone ever seen an 1864 with the optional cat O 3-pt hitch and PTO?
  2. #2
    Join Date
    Mar 2006
    Posts
    114
    Milan IN
    [2004 LT2180] [1980 582] [1981 582] [1983 682] [1983 982]
    Default Re: 3-Point Hitch & PTO for CC 1864
    I don't think Cub ever made one like that. I was always under the assumption that the rear PTO was a SGT item only. I been wrong before, and I can be wrong again though.
    AJ
  3. #3
    Join Date
    Apr 2009
    Posts
    50
    Fenton, MI
    1995 CC 1864 Hydro
    Although not a SGT, the 1864 essentially rides on the same basic frame as the SGT's and uses many of the same parts. Both the 3-pt hitch option (190-383-100) and the rear PTO option (190-433-100) listed in the 1863 service manual are identical between the model 1864 and the SGT's. It's just that I've never run across anyone with one on their 1864 -nor actually seen one installed on an 1864. I was hoping to find someone with it to see if they found either option to be useful. There are two 3-pt hitch versions: one that accomodates the rear PTO and one for tractors without the rear PTO option. Attached below is a photo of a non-PTO version of the 3-pt hitch (190-388-100).
    Attached Thumbnails Attached Thumbnails 3-Point Hitch & PTO for CC 1864-nfcat0-jpg
    Ken
    ___________________________________________
    2016 JD 1025R w/ factory installed loader/backhoe
    60" 7-iron MMM w/ auto connect
    54" 'Quick Hitch" front blade
    1995 CC 1864 Hydro (145-684-100)
    46" GT 3-blade mower deck (190-321-100)
    46" Triple Rear Bagger Grass Catcher (190-335-100)
    45" Two-Stage Snow Blower (190-551-100)
    Rear Weight Bracket Kit (190-447-100)
    10 Cu. Ft. Utility Cart (192-653/653a-100)
  4. #4
    New Member
    Join Date
    Jul 2013
    Posts
    2
    pittsburgh, pa.
    cub cadet/2182
    THIS REAR PTO KIT ACCOMMODATES MANY NARROW FRAME TRACTORS AS LISTED IN MANY OEM PARTS SUPPLIERS INVENTORY LIST SUPER AND NON; FOR EXAMPLE THE KIT FOR THE 2182 IS THE SAME FOR THE 982...190-433-100....
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
