kruss77
I have a model 1864 Cub Cadet with a Kohler CH18 engine that I知 having power loss issues with. Here are the details:
- Bought used in 2002. Ran great with NO problems until about 6 weeks ago.
- Power loss coincided with the replacement of the carburetor solenoid (perhaps just coincidental). (Previous owner had ground down the pintle on the old fuel shutoff solenoid. This is used to stop the flow of fuel to the carburetor jet to prevent backfiring when shutting down the engine.
- New solenoid appears to operate fine. Can see it working when looking down into the open carburetor fuel bowl.
- Power loss coincided with the removal and reinstallation of the fuel tank (perhaps just coincidental). (Same time as carburetor solenoid replacement.)
- Rebuilt the carburetor - no improvement.
- Rebult the fuel pump - no improvement.
- Replaced the fuel filter (3 times) - no improvement
- Thinking maybe there was water in the fuel, I flushed out the entire fuel system; replaced old fuel with fresh fuel no improvement. Replaced old fuel lines with new at the same time no improvement.
- Sometimes the power loss occurs immediately upon starting. Sometimes not until after a couple of laps around the yard.
- It will start and idle OK, but as soon as the engine sees a load, it loses power making it almost impossible to mow (or anything else for that matter).
- Engine still runs, just at a reduced power output and does not backfire or misfire.
- Sometimes the power goes in and out like someone is flipping a switch. Loss of power behavior is very erratic.
Is it possible the coil is going bad? Would that produce these kinds of symptoms?
