Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Jul 2009
    Posts
    2
    Default 3200 forward and reverse pedal problem
    I hope someone out there can help me with this problem.
    I have a 1 year old 3200 tractor that has about 30 hours on it. The forward and reverse pedals do not seem to work as well as they used to when it was new. The problem was that when I pushed the forward pedal it would move slowly and when I pushed the reverse pedal it would sometimes move extremely slow or not at all. I would have to push it a couple of times to get it to move in reverse.
    I had the dealer pick it up to repair it in warranty. The dealer said he adjusted it as best he could. It now does move faster in forward and does move in reverse, but you have to push the pedals very hard to get any speed in forward and reverse. It is very uncomfortable to hold the pedal down that hard when mowing. The dealer said to use the cruise control to keep the speed, but I do a lot of turning when I mow and that is not practical.
    Any suggestions on how this can be fixed?
    I致e been a cub cadet owner for over 30 years and have had some experience repairing them. I much prefer the lever on the older tractors then the pedals.
  2. #2
    Veteran Member JTKub's Avatar
    Join Date
    Apr 2005
    Posts
    1,560
    West Falls, NY
    Cub Cadet Z-Force 44
    Default Re: 3200 forward and reverse pedal problem
    Did the dealer replace the hydraulic dampener on the motion control linkage?? All it is s a tiny 'lift strut' like you'd see on rear hatch of a car. Basically it smooths/dampens the spring loaded action of the pedals to keep you planted in the seat more comfortably! Sounds to me like #1, your dealer is a possible boob, #2 the strut is bad.
    Joel
    Tractors of the past:
    2010 Cub Cadet Z-Force 44 fab
    2005 Cub Cadet 2544
    1979 Case 220
    2003 Yard Machines 17hp 42" transmatic (crap-matic)
  3. #3
    New Member
    Join Date
    Jul 2009
    Posts
    2
    No, I do not believe the dealer replaced any parts.
    Can you point me to the correct part in one of the 2 following attachments?
    I want to make sure the dealer understands when I send it back again for repair.
    3200 forward and reverse pedal problem-transmission-mount-png
    3200 forward and reverse pedal problem-break-control-png
    Thanks
  4. #4
    Join Date
    Jun 2004
    Posts
    706
    This look slike a design problem to me. I adjusted my backward speed to a crawl to get a little more forward speed. I finally made a modification to the reverse pedal so I now get decent speed both ways. See my post 6-23-09.
    http://www.tractorbynet.com/forums/c...-increase.html
    Bob B.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
