Page 1 of 2 12 LastLast
Results 1 to 10 of 18
  1. #1
    New Member
    Join Date
    Aug 2007
    Posts
    3
    Default 7000 series diesel won't start, need help!
    Hopefully someone here can point me in the right direction. I have a cub cadet 7000 that's been working great. I used it last sunday, put it in the shed and all was well. Last night I went to start it up and it won't fire. It turns over, I checked the filters and it's getting fuel. The only notable difference is my glow plug indicator light stays on. Usually it goes off after 5-8 seconds, then I'll try and start it. But it just stays on. I would think that it should still start as it's not that cold yet. I checked the fuse panel and all those are okay. The only thing I didn't check is the inline fuse. Could it be that? How hard is it to replace a glow plug? Any help would be very appreciated. Thanks
  2. #2
    Silver Member bwmarine's Avatar
    Join Date
    Feb 2009
    Posts
    101
    western michigan
    cub cadet 7235 - case 446
    Default Re: 7000 series diesel won't start, need help!
    Hmm, my tractor I never use the glow plugs... give it a little throttle and turn the key and its running.
    Im thinking fuel supply... water in fuel? fuel pump?
    2010 Kubota L3240 - land pride sb 1574, forks, loader
    (sold) 1995 Cub Cadet 7235 - loader, 6ft rear blade, 6ft box blade, 7ft rake, 3pt reese hitch
    2009 Cub Cadet 2550 - mower deck, dethatcher, sweeper, aerator
    1987 Case/Ingersoll 446 - snow blower, front blade, mower deck
    1998 Ranch King 4 Wheel Steering - mower deck
  3. #3
    Platinum Member OldMachinist's Avatar
    Join Date
    May 2006
    Posts
    638
    Southwest Illinois
    On most newer deisel engines the glow plug circuit has a electronic relay/timer that senses ambient temp and glow plug resistance. It sounds like the relay isn't sensing any resistance in the glow plugs therefor it isn't opening the fuel shut off solenoid. Check to see if there is voltage on the glow plugs with a test light or meter when you first turn the key.
    2006 Cub Cadet Z-Force50
    Agco Allis 1616H
    1974 SearsGT18 with 3 point,48"deck,Haban sickle mower and front dozer blade
    2000 Bobcat 453F with steel tracks
    1954 Ford860 with front end loader, 5' brushhog
    1952 Allis Chalmers CA with Woods L59 mower
    1947 Case SC
    1998 Honda ACTY 4WD mini truck
    And too many other small engine tools to list
  4. #4
    New Member
    Join Date
    Dec 2009
    Posts
    4
    Beamsville
    cubcadet 7235
    My 7235 just did the same thing. I am told it is the engine shutoff solenoid. They have to order 2 weeks they said and $260.
    If anyone knows where I can get one faster please let me know.
  5. #5
    Join Date
    Mar 2009
    Posts
    188
    Southwestern Michigan
    Cub Cadet 6284
    I think OldMachinist is correct. It seems to me that you should be able to tell if the engine is getting any fuel by watching the exhaust when the engine is cranking. When starting my tractor cold (with the throttle open) I can see white mist in the exhaust when it first cranks (indicating presence of fuel) which turns momentarily black as the engine catches and fires up. If the engine is not getting fuel I don't think you will see anything in the exhaust.
    JN
  6. #6
    Silver Member dweitzel's Avatar
    Join Date
    May 2006
    Posts
    136
    SE, IN
    Cub Cadet 7360SS
    Quote Originally Posted by gammata View Post
    What old machinist said. My 7360ss has a small 1.5" by 2" black timing module mounted to the firewall on the Right side of the tractor. Mounted by one bolt to the firewall. Common that they failed on the 7360 series. Cub has a new updated part that is suppose to be better. If your outside temp gets to be around 32 degrees F, mine will not start without the glow plugs.
    Dw
    1999 - 7360ss, 36 hp Mitsubishi, 4 cyl engine. 168 hours
  7. #7
    Join Date
    Mar 2009
    Posts
    188
    Cub Cadet 6284
    Good to know. Thanks for the feedback.
    Question - has anyone ever installed a by-pass for the glow plug timer to allow starting the tractor if the timer fails? I'm thinking that one could simply by-pass the circuit and use a push button (momentarily on) switch like a universal horn button to activate it. Of course one would need to be sure they didn't hold it down too long and risk burning up the glow plugs, but it does seem that it would serve well on a cold morning if and when the timer decides to take a dump until a replacement part could be acquired.
    JN
  8. #8
    Join Date
    Jan 2004
    Posts
    135
    Try unplugging the controller temp sensor wire from the rear sensor (I think) on the top water outlet. This will put the controller in max on mode which is good for 10-12 seconds every time. You probably don't want much more than that?
  9. #9
    Join Date
    Mar 2009
    Posts
    188
    Cub Cadet 6284
    Outlander,
    Fortunately for me the starting problem I did have was resolved by researching it on the forum and following the advice I found. I asked the question about by-passing the glow plug timer as a 'what if', but I appreciate the reply.
    Hopefully I won't ever need to use the trick you mentioned, but I'll keep it in mind if ever the glow plug timer acts up on my 6284 tractor. Tips like that could really save the day on a cold morning with a balky starting tractor.
    My 6284 is the first diesel powered machine I have ever owned. I really like it but there are some things different enough that there is a learning curve.
    Thanks!
    JN
  10. #10
    Join Date
    Jun 2004
    Posts
    706
    Quote Originally Posted by jnelson View Post
    Outlander,
    Thanks!
    JN
    I would research it well before bypassing glow plug controls. I had 2 early 80's GM diesel cars, a 1980 Bonnevile and a 1982 Cadillac De Ville. They both used 6 volt glow plugs for faster startup so they were energised for a very short interval.
    Bob B.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
