2 years ago I was running it and it started loosing power... fumigating the neighborhood in the process.
Changed Filters, oil, plugs and battery, good to go... well until last w/e.
I had used it the prior w/e and no issues, then went to start.... only ran on Choke with huge smoke out in the garage.....cofff cofff.
I again changed oil, filters, plugs but not the bat as that is only a year old and turns the motor with ease.
It only runs on Choke with lots of smoke out the exhaust. And I MEAN LOTS!!!!
I checked the fuel pump by turning over the engine with the fuel line disconected from the carb and fuel flowed... but maybe not enough???
If it runs it's getting spark... so the fuel is the only think I can think of. But it has 400 + hrs... so is it something more?
Should I just think of replacing the engine? I've read that the new fuels are causing problems with valves... hence may be adversely affecting the fuel pump as it runs off the diff/pressure in the valve cover... Maybe that's why it's not pumping fuel?
Any thoughts?
Any thoughts?
