Results 1 to 6 of 6
  1. #1
    Join Date
    Nov 2009
    Posts
    99
    Pittsburgh
    Default 6284 loader lift pressure
    I felt a little embarrased yesterday. I went to lift a piece of equipment on to a trailer, and the factory loader would not lift it, about all i can lift is my mmm with it.
    With that said, does anyone know how to adjust the relief pressure?
    I am going to throw some weights in the bucket and test it again to see where it stops lifting, but that equipment I was lifting could not have been more than 500 lbs, and I think the loader is rated about 750.
  2. #2
    Join Date
    Jan 2008
    Posts
    2,384
    Western PA
    John Deere 5083E MFWD, Kubota L3400 HST
    Default Re: 6284 loader lift pressure
    Where you lift it in the travel of the loader means ALOT. If its at ground level there is alot more lift available than higher in the air. Dont forget how you attached it. IIRC loaders are rated for their lift at the pins where the bucket attaches without the bucket on. Anybody feel free to correct this. So if you threw a chain from the top of the bucket out over the lip, then thats alot harder for the cylinders to lift.
    '11 John Deere 5083E, 563NSL Loader, MX10 Mower, 78" Bucket, Forks/Bale spear (interchangeable)
    L3400 Kubota HST Loader, finish mower, rake, scraper blade, Gin pole, Kustom Fab front hydraulic snow plow (Inspired by ASGAR)
    JD 550 Dozer 6 way blade and winch
    JD 450B Track Loader
    Case 480C Backhoe W/ Extend-a-hoe
    '01 International 4700 LP, DT530, Allison MD3060, Air Ride, Crew Cab
    '11 Moritz 20+5 14.5K GN with adj. Tail
    ''08 700R Raptor
  3. #3
    Super Star Member J_J's Avatar
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    Power-Trac 1445, KUBOTA B-9200HST
    Read your manual to find the pump pressure.
    Find the relief valve and install a gage and check the pressure. If lower than about 50 psi below the pump pressure, then adjust it to 50 PSI below max pump pressure.
    The relief could be on a valve or on a hyd block manifold.
    You will need a 3000 psi pressure gage like this .
    Attached Thumbnails Attached Thumbnails 6284 loader lift pressure-hyd-gage-qd-jpg
    Attached Images Attached Images
    J.J.
    When I works, I works hard. When I sits and thinks, I goes to sleep.
    Git er done.
  4. #4
    Join Date
    Nov 2009
    Posts
    99
    Pittsburgh
    Thanks JJ. While I cant seem to locate a service manual for my 6284, I found one for the 7000 series, which may be close enough.
    I have attached the section that is relevant.
    I will order a gauge and test.
    Attached Files Attached Files
  5. #5
    Join Date
    Sep 2003
    Posts
    18,924
    JACKSONVILLE, FL
    The relief pressure for the tractor in the pdf, is at 2133 PSI.
    After installing the gage, max out the cyl and read the pressure, and go from there. If it is to low, then adjust with shims or turn the relief nut in to increase the pressure.
    J.J.
    Git er done.
  6. #6
    Join Date
    Nov 2009
    Posts
    99
    Pittsburgh
    thought I'd post and update and share some info.
    Finally got a gauge and adapter this weekend, and hooked it up,
    I was indeed under max psi, I was about 1100.
    Looked in the 7000 service manual, and it said I had to remove fenders and right rears wheel to get at loader relief valve, after removing rear tire, I decided to get cut off grinder out and cu out about little less than 1/4" high and about 1" in length, this allowed me to slip on 7/8" wrench and loosen jam nut.
    In addition I was able to slip 7/16" socket on adjusting bolt.
    for reference, clockwise increases pressure and counter clockwise decreases pressure.
    I made final adjustment, and retightened jam nut, all is good now.
Similar Threads
  1. Replies: 13
    Last Post: 07-08-2011, 02:44 PM
  2. Loader Not Holding Pressure
    By shanem43 in forum Bobcat Construction Equipment
    Last Post: 05-10-2011, 02:53 PM
  3. Need loader lift locks..for an Allied....
    By Jer in forum Attachments
    Last Post: 05-03-2006, 09:22 PM
  4. Weak Loader on my new L39! What is going on?
    By mike69440 in forum Kubota Owning/Operating
    Last Post: 07-13-2005, 12:30 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
