Results 1 to 4 of 4
  1. #1
    Member JPPWNY's Avatar
    Join Date
    Jun 2005
    Posts
    41
    Rochester NY area
    Cub Cadet SLT 1554 and Cub Cadet GT3100
    Default Removing rear tire on Cub Cadet
    I didn't bring my tools with me to camp where my GT3100 is, so I couldn't do anything.
    I was assessing what needed to be done to remove the rear wheels of the tractor.
    Does this nut have to be removed first to remove the lug nuts? What size is that big nut, looks larger than 1 inch?
    Will that big nut loosen up or does something have to be held on the other side of the axle at the same time?
    ThanksRemoving rear tire on Cub Cadet-cub-cadet-rear-tire-jpg
    Stihl MS441, Stihl MS260 Pro, Stihl FS55
    Ariens 924DLE
    Cub Cadet 3100 54", Cub Cadet SLT1554
  2. #2
    Veteran Member Carl_NH's Avatar
    Join Date
    Apr 2002
    Posts
    2,173
    Coastal NH
    01 Kubota B21TLB, 2010 Ferris 52" ZTR, Cub Cadet 1811, Gravely Super8
    Default Re: Removing rear tire on Cub Cadet
    Remove the 4 lug nuts and the wheel will come off (lift up rear of tractor with a 2x4 and put a block under it first).
    The lug nuts are probably 3/4 or 15/16 in size - check your truck/car lug nut wrench - it may be close if you dont have any other tools.
    Why are you removing the wheels in the first place tho? Changing the tire type or loading with fluid?
    Kubota B21TLB, Ferris IS2000, Cub Cadet 1811
  3. #3
    Join Date
    Jun 2005
    Posts
    41
    Rochester NY area
    thanks for the reply...
    I am wanting to replace the turf tires with a better traction tire. Looking at Carlisle All Terrain tires.
    I get stuck too often on my trails in the woods and on the slope before the pond.
    Ariens 924DLE
  4. #4
    Join Date
    Apr 2002
    Posts
    2,173
    Coastal NH
    I did that on my 1811 - see the pic - I was lucky to find a guy on CL that had a 3205 that he got with lug style and he wanted turf so sold me his rear tires plus his front lug tires on the wheels for $250.
    It rides a little rougher but the traction is better. It's not a hard job to R&R the tires - just use some bead sealant on the new ones when you put them on it will be easier.
    Carl
    Attached Thumbnails Attached Thumbnails Removing rear tire on Cub Cadet-dcp00921-jpg
Similar Threads
  1. Cub Cadet RZT Rear Bumper or Not?
    By WSJ in forum Cub Cadet L&G
    Last Post: 04-05-2011, 02:18 PM
  2. rear discharge for cub cadet
    By wftree in forum Cub Cadet L&G
    Last Post: 05-22-2009, 09:58 AM
  3. Cub Cadet rear grass baggers
    By Lubrecon in forum Cub Cadet Tractors
    Last Post: 08-04-2005, 10:07 PM
  4. Cub Cadet 3204 Rear Traction
    By ronT in forum Cub Cadet L&G
    Last Post: 06-01-2005, 03:49 PM
  5. removing a rear tire
    By Mosey in forum Tires
    Last Post: 09-17-2002, 12:26 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
