Results 1 to 5 of 5
  1. #1
    Default 1020 Won\'t Start
    The battery is fully charged, starter ok(brand new), and ignition does make an attempt to turn(clicks) It does not really crank over but it tries. Troubleshooting advice would be nice. Thank you
  2. #2
    Gold Member
    Join Date
    Apr 2004
    Posts
    335
    Spencerport,NY
    Jinma 284
    Default Re: 1020 Won\'t Start
    With all the safety switches..make sure there working..I remember a safety switch on the brake pedal,a no start switch on the blade,(blade must be in off position)I don't remember if the seat switch will prevent start or prevent blade engagment? let us know [img]/forums/images/graemlins/ooo.gif[/img]
  3. #3
    Elite Member
    Join Date
    Mar 2004
    Posts
    2,588
    Central Ma.
    Kioti NX4510HST
    Try turning the motor over by hand and see if it will in fact turn over a complete revolution.
  4. #4
    Do the safety switches have to be removed to be checked? The one under the seat(must be seated to start & mow) is the only one that i'm familar with as far as exact location. Can an ohm meter check this while they are attached? I'm a first time homeowner and just starting to learn the basics...sorry that this stuff is so elementary!
  5. #5
    Elite Member
    Join Date
    Mar 2004
    Posts
    2,588
    Central Ma.
    Kioti NX4510HST
    You should be able to check the switchs without removing them. Just make sure that they are in the closed position. But first, I would make sure you can turn that motor over by hand before you go any further.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
