dqdave1
1050 with 50\" mower problem
My 1050 with 50" mower has never cut properly. It leaves an uncut area from the center blade. I mow on 4 or 5 and even by going very slowly it does it. To get a nice job, you have to double cut the lawn. It came with a triple bagger. When I received it, the dealer had installed two high lift blades as per the bagger instructions. ( on outer blades). After all the problems cub had the dealer install a high lift blade in the center position. No help. Belts are routed correctly ( double checked); blades are sharp, spindles rotate freely, deck is adjusted properly ( 1/4 lower in front) I believe the center pulley does not get enough of the belt around it to keep from slipping. Any help would be appreciated.
