Hello Tractor Heads- I am constantly amazed by the information on the web and by the good people who will share their knowledge and help each other out. Sounds like B-kissin but it's true- who thought that there would be a discussion forum on garden tractors! Kudos to you all!
So- I have a question:
I have a 1995---2160 Cub Cadet tractor. It is NOT an auto trans but the manual with 6 speeds. Love the "Beast" as my son calls it-
Over the years the shifter has developed a lot of play front to back. Meaning the shifter must move at least 2 or 3 gear indicators before it will engage the next gear. I can get all six gears but neutral is unreachable. The shifter hits the end of its slot before in can reach neutral. Not a huge deal but the tractor deserves neutral!
The clutch/ or forward/reverse pedal still works pretty well, very little slippage if any.
I drained and filled the trans/rear end with new recommended fluid, it did make small improvements in the overall function of everything, but I still can't get neutral.
Can anyone tell me what's going on inside the trans. I looked for some external adjustments but saw none. I love to do maintenance on such equipment or simple tinkering- but I don't think that I am one to tear down the rear end.
Any advise would be appreciated-
Pardon the long post-
Thanks-- solds
Thanks-- solds
