OhioGuy
- Joined
- Jul 23, 2003
- Messages
- 591
- Location
- Northeast Ohio
- Tractor
- Ford 1220, Case 245, Cub SZ60, Cub 2284
I have a recently purchased 1872 that has two problems that I've spent a fair amount of time on, with limited success.
I'm intermittently losing spark. My neighbor loaned me a in-line spark indicator and the tractor will start 90 percent of the time, on that tenth attemp, no spark. I'm leaning toward the ignition module but that requires pulling the engine so I thought I'd ask here first and see if there is any other likely culprit.
There is a huge diagram of the ignition switch on the inside of the hood. A blind guy must have replaced it?
Maybe an intermittent PTO switch?
Maybe intermittent Oil pressure switch, could just unpug or jump that one?
The hydro problem is both pressure relief valves shooting a burst of oil on startup. I removed both and soaked in mineral spirits, put them back in and they seemed to be working fine. The next time I lost spark, it's guyser time again. But they were dry for a bunch of other testing.
The tractor is possessed, maybe I need a priest!
Curt
Curt
