Results 1 to 10 of 10
08-11-2011, 09:26 PM #1Platinum Member
- Join Date
- Jun 2004
- Posts
- 529
3235 PTO Belt Replacement
I was unable to find very much info about replacing the PTO belts so I'm posting my experience today replacing the matching pair of belts. I imagine all 3000 series & perhaps others are similar. My belts were glazed and cracked with 1 belt having a deep crack. The mower seemed slow to come up to speed & sounded like it bogged down at times.
I removed the side panels but NOT the hood or grille. I removed the sheet metal shroud, mounted between the engine & the grille, by 4 cap screws. I loosened the 2 large studs, below the large pulley, enough to allow the belts to slip between the pulley & studs. They are there solely to prevent the belts from jumping off the pulley. I removed the upper belt retaining bracket, held on by 2 cap screws. I unhooked the upper end of the spring on the PTO engagement arm. The belts can now be worked off the pulleys & slid between the PTO brake & pulley, front belt first & then the inner belt. Reverse the procedure for installation. The entire job can be done in an hour. My belts were original & 7 years old with 376 hours.
Bob B.
08-11-2011 09:26 PM # ADS
06-27-2012, 02:40 AM #2New Member
- Join Date
- Jun 2011
- Posts
- 4
- Tractor
- MF 261, JD790
Re: 3235 PTO Belt Replacement
Works for cub cadet 3186 as well. Thanks, this was very helpful!
06-27-2012, 08:23 PM #3Platinum Member
- Join Date
- Jun 2004
- Posts
- 529
An update to the belt replacement. I don't know if the replacement belts I bought on eBay were of poor quality but they only lasted 25 hours. I replaced them again but this time was able to do it by only removing the tension spring and loosening the 2 belt retainer studs. By laying on the ground under the front of the tractor I was able to bends the retainer brackets enough to slip the belts off and on.
Bob B.
06-27-2012, 09:23 PM #4New Member
- Join Date
- Jun 2011
- Posts
- 4
- Tractor
- MF 261, JD790
I bent the belt retainers too. I've just ordered belts from v-belt supply and waiting for them to come. here is a link. with shipping about $8 each for 4. hopefully the kevlar will last. 4LK400 Kevlar V-Belt
06-28-2012, 08:57 PM #5Platinum Member
- Join Date
- Jun 2004
- Posts
- 529
07-06-2012, 04:48 AM #6New Member
- Join Date
- Jun 2011
- Posts
- 4
- Tractor
- MF 261, JD790
of course the belts didnt fit. Off to the Cub dealer to get the right ones...i'll never learn.
07-06-2012, 07:45 PM #7Platinum Member
- Join Date
- Jun 2004
- Posts
- 529
I won't order those belts then.
Bob B.
07-06-2012, 10:08 PM #8New Member
- Join Date
- Jun 2011
- Posts
- 4
- Tractor
- MF 261, JD790
got the new belts and put them on, no problems, runs great. hope they last!
06-13-2013, 02:49 PM #9New Member
- Join Date
- Jun 2013
- Posts
- 1
- Location
- Culpeper, Virginia
- Tractor
- Cub Cadet 3235
Thanks for your post. I have little mechanical ability but was able to follow your instructions and change the belts in about an hour.
06-15-2013, 01:52 AM #10Platinum Member
- Join Date
- Jun 2004
- Posts
- 529
Glad it helped. My belts are still going strong. In 9 years of use I've changed the 54 inch mower belt once and the PTO belts twice because the second set were apparently inferior. I still have the original battery and just started hooking up a Battery Tender last winter to keep it charged over the winter. When it finally goes it will probably just die completely.
Bob B.
Similar Threads
RZT Transmission Belt Replacement...HELP!
By RZT50 Rider in forum Cub Cadet Yanmar & CUTsReplies: 19Last Post: 05-23-2013, 10:36 AM -
Model 111 drive belt replacement
By rabbitrandy in forum John Deere Lawn & GardenReplies: 6Last Post: 08-12-2011, 10:22 AM -
How to tell if rear mowing deck belt needs replacement?
By Ezzrider in forum Kubota Owning/OperatingReplies: 14Last Post: 07-31-2011, 09:16 AM -
Ford 8n Fan Belt Replacement?
By blount2000 in forum Parts/RepairsReplies: 3Last Post: 05-17-2011, 12:32 PM -
Help with 3204 PTO (vac) belt adjustment
By slipnfall in forum Cub Cadet L&GReplies: 4Last Post: 03-18-2010, 09:10 AM
