Results 1 to 4 of 4
  1. #1
    New Member
    Join Date
    Mar 2012
    Posts
    3
    Providence Forge, Va
    Default 3184 Fuel Problem
    I have a 3184 I think its about 10 years old and it has been great all of those years. Its starts but when I release the key it shut down, as long as I hold the key on it runs fine. Thier must be a switch that is shutting down the fuel but I cant find one. I hoping that someone can help me track this down.
    Thanks,
    Steve
  2. #2
    Join Date
    Jun 2004
    Posts
    517
    Default Re: 3184 Fuel Problem
    Maybe you have a bad ignition switch. Are you saying that holding the switch in the cranking position allows it to run and releasing it to the normal ON position it stops? There is a separate contact in the switch to provide voltage to the coil while cranking and when you release the switch it uses a different contact.
    Bob B.
  3. #3
    New Member
    Join Date
    Mar 2012
    Posts
    3
    Thanks Bob I will check this next week.
    Steve
  4. #4
    New Member
    Join Date
    Mar 2012
    Posts
    3
    Bob my problem turned out to be a bad safety switch on the seat.
    Steve
Similar Threads
  1. Fuel line connector problem
    By Tibbits in forum Owning/Operating
    Last Post: 07-14-2011, 10:23 AM
  2. Briggs Fuel Pump Problem 19.5 HP
    By monsterdad1 in forum Craftsman / Sears
    Last Post: 06-11-2011, 11:24 PM
  3. Oil & Fuel Fuel problems (algae)
    By rxk9394 in forum Kubota Owning/Operating
    Last Post: 01-08-2010, 04:36 PM
  4. Oil & Fuel A little help with a fuel problem......
    By williekioti in forum Kioti Owning/Operating
    Last Post: 01-13-2008, 01:10 AM
  5. Ford 800 fuel problem
    By dfoley in forum Parts/Repairs
    Last Post: 09-03-2002, 08:49 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
