Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. #1
    New Member
    Join Date
    Apr 2012
    Posts
    8
    saint johns, michigan
    cub cadet 7275
    Default 7275 injection pump question
    Hi,
    I have a 7275 cub cadet tractor that reved high and the key would not shut the tractor down. I had to turn off the fuel supply at the settlement bowl to shut it down. I did not run out of fuel. I cleaned the fuel filter and I bled the lines and have fuel going into the injector pump but don`t have any coming out of the 3 lines going to the injectors. Any thoughts on my next steps to try? If I end up pulling the injection pump do I have to first remove the govoner?
  2. #2
    Administrator
    Join Date
    Mar 1998
    Posts
    9,049
    San Diego, CA
    None currently
    Default
    Welcome to TBN.
    Muhammad Chishti
    Administrator
  3. #3
    New Member
    Join Date
    Apr 2012
    Posts
    8
    cub cadet 7275
    Default Re: 7275 injection pump question
    Thanks Muhammad, This looks like a very good site where I`ll be able to learn a lot.
  4. #4
    Elite Member
    Join Date
    Jun 2011
    Posts
    2,517
    NE Oklahoma
    MF 230 and Mitsubishi D2000
    Welcome to the forum from Oklahoma.
    Ken
  5. #5
    New Member
    Join Date
    Apr 2012
    Posts
    8
    cub cadet 7275
    Thanks Ken
  6. #6
    Join Date
    Jan 2012
    Posts
    65
    Cub 7274
    My 7274 died on me- shut it down then would not start
    I had to have the injection pump rebuilt as the fuel was not going past the pump to the injectors
    There are "shims" that control the timing I believe
    I had it done by a business and the cost was $1700 to remove repair replace
    Runs fine now
  7. #7
    Veteran Member moored4's Avatar
    Join Date
    Jan 2011
    Posts
    2,368
    Great NorthWest /Southwest Washington
    Kubota l245dt, l3540, 8N
    to TBN!
    Happy ing!
    "keep them pots black, shiny, and full of good Food and Fellowship!"
    Moore Cookie
  8. #8
    New Member
    Join Date
    Apr 2012
    Posts
    8
    cub cadet 7275
    Cub7274
    It may be the pump broken, but I took the inspection plate off and the 3 injector ports off the top of the pump and found no obvious broken parts or pluged injectors so I`m thinking it may be the selonoid on the front of the injector pump. I ordered a new one it cost about $150 dollars so I hope I`m right. It said it would be at my place between the 19th and the 23rd. Thanks for your responce and help. I`ll let you know if the selonoid solves the problem. I read that if the selonoid is bad the valve will not open thus keeping diesel fuel to be pumped out the pump into the injectors.
  9. #9
    Super Star Member
    Join Date
    Jul 2011
    Posts
    10,413
    Yanceyville, North Carolina
    Kubota L4400
    Welcome aboard. Best wishes.
    The PUPIL who does not surpass his Master, fails his Master.
  10. #10
    New Member
    Join Date
    Apr 2012
    Posts
    8
    cub cadet 7275
    Thanks Creekbend
Similar Threads
  1. Kubota BX24 Injector pump problem
    By fred98050 in forum Kubota Owning/Operating
    Last Post: 08-20-2012, 04:41 PM
  2. Iseki TU1700 Injection Pump Removal
    By gilbertmsg in forum Parts/Repairs
    Last Post: 04-11-2012, 11:58 AM
  3. Urgent Well Pump Question
    By Stringer in forum Projects
    Last Post: 09-15-2010, 11:46 PM
  4. Well Pump Question
    By Believer in forum Projects
    Last Post: 09-07-2010, 09:08 PM
  5. Oil & Fuel TY290 engine / 2i70 fuel injection pump
    By kingjames8283 in forum Chinese Tractors
    Last Post: 01-25-2007, 09:48 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
