Go Back   TractorByNet.com > Brand Specific Forums > Cub Cadet
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 06-12-2009, 12:54 PM   #1 (permalink)
New Member
Default New Guy with a 2145 Project Needs Help
Hi All,
I was directed to this site by a member of the tractor forum over at the gardenweb.com. I've got a Cub specific issue there just aren't enough owners over there to help me out.
Here's the situation. I'm pretty handy when it comes to mechanical thing cars, tractors, lawn mowers, etc. Got a call last week from a neighbor there's a gal in town who's a little tight on cash, (recently divorced) and has a non-working tractor. I was asked if I'd take a look at it and see if I could get it up and running. My labor will be free and another neighbor will cough up the cash for parts.
What she's got is a Cub Cadet model 2145 with a 42" deck. From what I've found on the net, it probably came of the assembly line back in the early to mid 90's. The machine has 350 hours it looks its age, but it's not hammered. It last ran 2 years ago. I'm told the PTO belt shredded while in operation -- the tractor was parked in the shed right after the failure and hasn't moved since.
One of the front tires are flat, battery dead, and indeed, the PTO belt is shredded. As the machine is in a rather confined area, I really couldn't do much more than look things over tying to note the obvious. The woman has the original owner's manual so that along with the Cub site, (really nice for parts) has given me something to digest. The exploded illustration of the deck shows there should be an anti-scalping roller on the front something I didn't see when I looked at the machine. The other night I made a second trip this time with a flashlight and a specific place to look. Much to my horror below is what I found:
As you can see, there's rope tied around the existing bracket, so this tells me the missing bracket probably came off well before the failure. God knows what other damage was done running like that. I plan to pull the deck this weekend to check for wear and tear.
I'm not throwing in the towel just yet. As long as everything else checks out and / or can be fixed with minimal $$, I'm going to try and fabricate a new bracket. The answer to my first question needs to come from a 2145 owner. I've noticed that the deck, as mounted, is off-set with the right side slightly back from the left. This being the case, the right bracket should be longer than the left. What I'm looking for is the measurement below. From the edge of the deck front to the most forward point hook slot.
Can anyone help with that? While I'm at it, has anyone had a situation like this making / replacing a front deck bracket? Any ideas as to how to proceed? I'm thinking of getting a 12~14 gauge sheet of metal and just cut, drill, & grind it out. I have the existing bracket to use as a template just need to get the proper length for the new one.
Thanks for the attention,
Jay
Jay_NJ is offline   Reply With Quote
Old 06-12-2009, 02:04 PM   #2 (permalink)
JTKub's Avatar
Default Re: New Guy with a 2145 Project Needs Help
Jay I wouldn't do anything until you can pull that deck and see how badly rusted it is. It's likely there's not enough metal to bother doing any custom bracket fabbing on it. I suppose you could weld or bolt a large rectangular sheet steel patch on the outside for reinforcement, then attach a custom bracket to that. Other than that, fleBay is your friend for tractor parts! >> Cub Cadet 42 inch deck - eBay (item 270405404403 end time Jun-13-09 17:11:16 PDT)
Joel
__________________
2005 Cub Cadet 2544
1979 Case 220
Tractors of the past: (eyes well up)
2003 Yard Machines 17hp 42" transmatic (crap)
1992 John Deere GT262
1970 John Deere 110
JTKub is offline   Reply With Quote
Old 06-14-2009, 03:51 AM   #3 (permalink)
Gold Member
micman32's Avatar
I can see why the belt shredded. Dang! I hope you can get it going again!
It would probably be easier to find a used deck like Joel suggested.
__________________
2003 Cub Cadet 2518 w/ 44 inch Deck
Triple Bagger
micman32 is offline   Reply With Quote
Old 06-15-2009, 10:19 AM   #4 (permalink)
New Member
Pulled the deck off yesterday afternoon. With the exception of the missing bracket, it's in surprisingly good shape. No major rust at all. All pulleys are tight as well as the spindles. The deck belt is shot, but that's understandable.
Sealed and filled the front tire, installed a new battery, and cleaned 5 dead mice complete with bedding from around the flywheel -- what a mess. Anyway, with the help of a little starting fluid, she fired up quite well. I still need to drain the old gas, change the filters and such, but she's running strong.
I plan to follow through with the bracket fabrication -- just wish I had that measurement to be sure of a proper fit. I'll post back with the final results when done.
Old 06-15-2009, 11:58 AM   #5 (permalink)
Gold Member
OldMachinist's Avatar
If no one gets the measurement for you try this. The back edge of the deck is straight and should be parallel with the rear axle. So flip the deck over and measure the distance from the rear edge of the deck to the front edge of the unbroken bracket. You should be able to determine the length of the missing bracket by moving over and measuring to the mounting area where it broke and subtract that from the unbroken measurement.
__________________
2006 Cub Cadet Z-Force50
1974 SearsGT18 with 3 point,48"deck,Haban sickle mower and front dozer blade
2000 Bobcat 453F with steel tracks
1954 Ford860 with front end loader, 5' brushhog
1952 Allis Chalmers CA with Woods L59 mower
1947 Case SC
1998 Honda ACTY 4WD mini truck
And too many other small engine tools to list
OldMachinist is offline   Reply With Quote
Old 06-15-2009, 04:33 PM   #6 (permalink)
New Member
Thanks -- great idea, but the whole darn thing is off-set.
The only guides I can use are the deck's rear wheels and handles on the deck. They are parallel to the front and rear wheels of the machine. Push comes to shove, I'll guesstimate using my geometry skills and then put the deck back on the tractor & measure where I think the bracket should be. If the two are close, I'll be happy.
Old 06-15-2009, 06:25 PM   #7 (permalink)
Gold Member
Yeah I see now that it's a two blade deck. I guess you could hang it from the rear hangers and take measurements to the front axle. It's not that critical because the front hanger u has adjustment nuts for leveling the deck.
Here a couple of downloads for you.
Owners Manual
http://www.mediafire.com/?lzmztmdnjmj
Service Manual
http://www.mediafire.com/?jzzymdm3nnn
__________________
1947 Case SC
Old 06-16-2009, 11:45 AM   #8 (permalink)
New Member
Much appreciated. I have the owner's manual, but not the service. It's amazing how you can download almost 300 pages of text in less than a minute! Again, thanks very much -- I'm sure it will come in handy.
Old 06-17-2009, 02:36 PM   #9 (permalink)
JTKub's Avatar
Quote:
Originally Posted by OldMachinist View Post
...I guess you could hang it from the rear hangers and take measurements to the front axle. It's not that critical because the front hanger u has adjustment nuts for leveling the deck.
Right on. You could hang it, throw a straight edge on the front of the U-hanger and measure to the front of the deck as she hangs. Problem with front U-hanger is, what you adjust on one side effects the other.
Joel
__________________
2005 Cub Cadet 2544
1979 Case 220
1970 John Deere 110
Old 06-19-2009, 10:46 PM   #10 (permalink)
New Member
OK, tomorrow I'm going to begin the process of fabricating the missing bracket. Tonight I began lining things up and it just doesn't look right. Would the general consensus be that the existing bracket is bent to the right or is this the way it should be? It makes a big difference in the measurements as there's an anti skid roller that needs to be placed between the brackets. Personally, I think it's bent - stands to reason that the bracket should come out straight from the deck.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Page generated in 0.07578 seconds with 8 queries
