Go Back   TractorByNet.com > Brand Specific Forums > Cub Cadet
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 10-01-2009, 08:40 AM   #1 (permalink)
moe1942's Avatar
Default 2542 cut
Does anyone else experience a lousy cut with this tractor? seems mine leaves a small uncut strip. I have checked everything numerous times and still have the problem. The gap between the blades is much smaller than the strip of grass.
moe1942 is offline   Reply With Quote
Old 10-01-2009, 09:06 AM   #2 (permalink)
New Member
Default Re: 2542 cut
I have the 2544. I have the same problem too (strip on the right), but only if I set the cut too low or if mud or grass has built up on that side of the deck. I keep it clean underneath and keep my setting a little higher.
ran007 is offline   Reply With Quote
Old 10-01-2009, 10:35 PM   #3 (permalink)
Member
jcomp's Avatar
check the guide wheels they should just be touching the grass when you mow. also make sure you don't have a bent blade and the deck is a click nose down out of level.
jcomp is offline   Reply With Quote
Old 10-02-2009, 08:29 AM   #4 (permalink)
moe1942's Avatar
Thanks for the replies. I think someone on MTF might have nailed the problem. I left the mulcher plug in after doing the leaves last fall. Think grass buildup may be causing the problem. Will take it out and cut the grass and see if it corrects the problem.
Rann007 what you said sort of confirms that suspicion...
Old 10-02-2009, 08:31 AM   #5 (permalink)
New Member
Yeah, keep that deck shiny underneath if you can. It's the #1 cause of rust and wear.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Page generated in 0.03933 seconds with 8 queries
