HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > Brand Specific Forums > Cub Cadet
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 11-02-2009, 09:58 PM   #1 (permalink)
Member
Default 2185 brake safety switch
Yet another problem with this POS 2185. Turn the key and nothing. Where is the brake safety switch located at? And can you just disconnect it to see if that is what the problem is?
With in the past year lets see:
Both coils
Rectifier
Stator
Wheel Bearing
Electric PTO Clutch
3 pullies
headlight assembly
jgrinn is offline   Reply With Quote
Old 11-03-2009, 07:32 PM   #2 (permalink)
Default Re: 2185 brake safety switch
could the safety swith under the seat be the problem?
Donsyl is offline   Reply With Quote
Old 11-03-2009, 09:49 PM   #3 (permalink)
Member
The safety switch for the seat has already been disconected. I am pretty sure its the one when you push down the brake pedal to start the tractor.
Old 11-04-2009, 12:26 AM   #4 (permalink)
Gold Member
OldMachinist's Avatar
The switch is inside the frame along the right side. You should be able to see it if you follow the linkage.
__________________
2006 Cub Cadet Z-Force50
1974 SearsGT18 with 3 point,48"deck,Haban sickle mower and front dozer blade
2000 Bobcat 453F with steel tracks
1954 Ford860 with front end loader, 5' brushhog
1952 Allis Chalmers CA with Woods L59 mower
1947 Case SC
1998 Honda ACTY 4WD mini truck
And too many other small engine tools to list
OldMachinist is offline   Reply With Quote
Old 11-04-2009, 12:50 AM   #5 (permalink)
Gold Member
Here's a couple of images for locating the switch and testing. The switch is number 17 on the parts breakdown.
__________________
1947 Case SC
Old 11-05-2009, 06:00 PM   #6 (permalink)
Member
Thanks for the info Old Machinist!! It ended up being the fuse down near the starter. I forgot that there was a fuse down there, I knew the one near the ignition switch. Once I realized that I wasn't even getting dash lights, I was pretty sure it was some type of electrical problem. But I am pretty sure that the brake switch is going bad, sometimes it won't start, I have to try a few times (and the dash lights are on). Thanks again.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.16573 seconds with 8 queries
