HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Customization
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 07-15-2007, 05:00 PM   #1 (permalink)
Default almost finished the build of mid mount mower
If you guys remember the other forum a few weeks ago I was looking for a belly mower for the like new (117 original hour) B7200 Well I got tired of hunting and of course impatient and decided to build something out of what I had here. My tractor was never equipped with a belly mower so first I took the front pto assembly with reversed drop box off of my fathers b8200 tractor. Second I located a b8200Hydro deck(just as nice as my tractor never used and stored indoors) not too far away. through some close research and measurement I figured out that the actual mounts on the RC60-72 and Rc60-82H are with in MMs So I used this. I didn't want to mess with building the four mount brackets so I bought four new from kubota dealer. I reversed the gearbox and was able to take the drive shaft off of that tractor and cutt it off at the base and take the one we have here from a Rc60-25 and cut it to size and weld it in place. If you very carefully cut the welds off at the base of the shaft it willfall out and give you a place to insert the new shaft to be welded and have a nice straight balanced shaft again, but this time the right length. I was able to modify the brackets I got with theh mower deck to fit my application. I took my time here and tack this and tried that. I didnot want any tension or wear points when the mower deck was installed. I then Took all my pieces in fabbed into our body shop and finshed the welds and primed and used XoXo orange paint. It is amazing how close the orange paint is to my older but still shiny B7200. The only mods I have left are I have to finish the install on my front pto drop box. I had a hard time holding the unit and stepping the drill to the proper size. Pinched drill bit and blood shed and of course a little $&#*$& I decided to wait until tomorrow until I can put into vice. One I finish this I should Be able to try it out and then move on to the install of power steering. Thanks.
wil3404 is offline   Reply With Quote
Old 07-16-2007, 03:33 AM   #2 (permalink)
MJPetersen's Avatar
Send a message via Skype™ to MJPetersen
Default Re: almost finished the build of mid mount mower
You need to give us some pics to look at. Some of us are "spacially challenged" and need a pic to get the pic. If you know what I mean.
Mike
__________________
"In all your ways acknowledge Him and He will direct your paths" Solomon
YM1510D, YM 1202 tiller, KK copy dirt scoop, imitation Gannon rollover box blade, and a Rear Blade with gauge wheels
MJPetersen is offline   Reply With Quote
Old 07-16-2007, 08:36 PM   #3 (permalink)
Sorry about that. Here is some pictures. I didn't want to add too many at once. I have more in anyone wants to see them. I mowed about 10 passes and man what a clean cut. I need to resize the rear "tenison bar" tomorrow and I"ll be good to go. I finished assembly after the pictures were taken.
Old 07-17-2007, 01:13 AM   #4 (permalink)
Jae
Member
Jae's Avatar
Looks like a quality job..
I wish I had a setup like that on my lil Kub L175. Mind you, my lil kub isnt quite as pretty as yours is, but it is still chuggin along....
__________________
Jae...
-= New Holland TC35DA ~124 HRS =-
Jae is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
