#11 (permalink) | |
Super Member
Quote:
![]() Land Leveler
__________________
Jim |
#13 (permalink) |
Gold Member
No, this is the ultimate boxblade with gage wheels.
__________________
Kubota BX23, BT600 BH, LA210 FEL, Maschio L125 tiller, Gearmore BB 20-48 BB, King Cutter 6' rear blade, Homemade PHD, Brinly BST-50 broadcaster, ? 6' cultipacker, log & chain drag. |
#14 (permalink) |
wow that is some nice equipment and what the heck is that giant thing bx23barry.
Had a chance to use my 60" box scrapper alot the last 2 days cutting a drain swale thru the wooded part of my yard, have not had much experience with it in the past but one thing I learned quickly is that it's much more forgiving than a rear blade or even a front bucket for level cutting into the ground, I tried the rear blade and made such an uneven mess in short order. Same with the front bucket, once you ride over a little bump your digging in one side more than the other and then it's just down hill from there, I mean I had this little swale so messed up that the tractor almost tipped in otherwise level terrain. With the box scraper it levels as it digs making things much easier, even though it may take less bite in each pass in the end it's a better job done
__________________
JD 4310; E hydro, 300CX, 48 BH, 60" box, 72" rake, 72" rear blade, cast pallet forks, 61"HD & 73" high volume bucket. FORD 1700; 2 WD, 2600 hrs. JD 320; Hydra lift, 48" deck and 48" snow blade. |
#15 (permalink) | |
Super Member
Quote:
I'd pay money for a joyride on one of these. ![]()
__________________
Jim |
#16 (permalink) | |
Gold Member
Quote:
__________________
#17 (permalink) | |
Gold Member
Quote:
Not really a box blade but a real serious dirt mover setup. ![]()
__________________
#18 (permalink) | |
Quote:
__________________
Paul in VT I used to own an ant farm but had to give it up. I couldn't find tractors small enough to fit it. -- Steven Wright |
#19 (permalink) | |
Quote:
__________________
#20 (permalink) |
Nice work. I'm jealous. I've got so many rocks that a smooth result would be a pipe dream
__________________
2007 TC40DA, Supersteer, ANBO Grapple Rake with WR Long Joystick rocker control, Landpride 72" Box Scraper, 84" Rake, 72" Disc Harrow,72" Spring Tine Harrow, 72" Woods Rotary Cutter, Pallet Forks, 60 gallon Cropcare 3-pt sprayer, 72" 3-pt chain drag,Vicon 3-pt spreader |
| Thread Tools | |
| Display Modes | |
| About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com |
