wushaw
Elite Member
I had 171lbs on the ft. and need to add more weight to my little 15hp Mitsubishi so I went to my metal place and found a small pallet of lead and the perfect container to put it in. A 4" square 1/4" wall tube almost 33" long.
I capped off one end of the tube and used my torch to melt the lead into the tube ( I used a fan to keep the fumes away) I came out with 183lbs of weight.
I capped off that end after it cooled the next day and layed it on top of the RR track I already have on there and welded it to the track, I used my stick welder 6011 rods and put down three beads on each side.
I think it turned out pretty good and now have 354lbs to help with my 400lb tiller or whatever else I hook up to it.
I spent $43.00 for the lead and tube, I don't know what real tractor weights cost but I figure I got out pretty cheap and the weight I already had on there didn't cost anything.
Two of the pictures is what I had left over from the pallet of lead.
The picture of the welding clamp is one of them magnetic switch types that is just the cats meow for when you don't have a thin place to attach your ground clamp.
