#12 (permalink) |
New Member
Nice work. That clamp on reciver ought to do the job. Looks heavy duty. By the way, if I brought that in the house and plopped it down on the counter top the wife would crap a blue bean....
Good clean work and nice welding. Had my eyes on a Hobart 10000 Champion. Hope to move up from my cracker box. |
#14 (permalink) |
Aching,
I've seen it but haven't had a chance to use it. Can you explain to me how it actually works. Is there an indicator on it. Offline is fine if you prefer that. Thanks in advance. Marty |
#15 (permalink) |
The receiver lower bucket clamp was bought on e-bay. It couldn't go take the time and now gas and find all the pieces parts for 56 dollars. I wish my welds were like that. ha
The counters are mine and she just uses them (not - she was still at work). |
#16 (permalink) | |
Gold Member
Quote:
#17 (permalink) | |
Elite Member
Quote:
![]() Also, as mentioned, always weld outboard hooks on in line with the loader arms. You can get by with them located on the outer edge if you never use the loader to lift anything heavy, but if that is the case, why do you need the loader to lift anything with a hook anyway? As I've mentioned before, I've relocated several hooks from the outside of buckets to be in line with loader arms after damage has been done, but I've never been able to fix the damage done to the loader after it was twisted by having hooks located incorrectly on the outer edges.
__________________
1982 19" Murray push mower (upgraded to B&S 8 hp engine!) Weed Eater 25cc string trimmer w/ curved shaft! 1978 Ford pickup, stick shift, 300ci 6 cyl *new rear U joint* 2006 Harbor Freight claw hammer *new* 2008 Harbor Freight pipe bender. Not sure what I'm going to do with it, but my dad figured I needed it for my B'day. 2008 Harbor Freight package of blue nitrile gloves (yup, from my dad too) ![]() Have you ever noticed that the more you learn, the more you realize what you don't know? |
#18 (permalink) |
BTW, most repair manuals say to just disconnect the negative side of the battery terminal. That's all I ever do on any of my equipment (bike, tractor, etc.).
#20 (permalink) |
I bought the weld on hooks but never used them I just got a receiver tube welded to a piece of angle iron and bolted it on, the reason I bolted it on was because I wasn't sure how it would work out, that was three years ago before every one started doing it (not saying I was the first) so I hadn't heard any positive feed back.
Now I would just weld it on because there is no reason to remove it, it's really the most simple useful thing you can do, jockeying trailers, hooking ropes, cables or chains, even made a gin pole. I don't think you need the hooks once you have the receiver, with the hooks on the sides you have to use both to get an even load, with the center mounted attachment you have that solved, at least in my case I have never once wished I had the welded hooks, but couldn't live without the receiver tube. JB,
__________________
JD 4310; E hydro, 300CX, 48 BH, 60" box, 72" rake, 72" rear blade, cast pallet forks, 61"HD & 73" high volume bucket. FORD 1700; 2 WD, 2600 hrs. JD 320; Hydra lift, 48" deck and 48" snow blade. |
| Thread Tools | |
| Display Modes | |
| About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com |
