#11 (permalink) | |
Member
Quote:
__________________
MX 5000 , SE-8, RF74 flail mower ,post hole digger ,6ft Box blade,landscaper .Howard Price 360z |
#13 (permalink) | |
Quote:
Very nice! I test drove a cab tractor yesterday...but it probably will be out of reach so I have questions! - what you mean by windows being bonded? - is the sunroof a pre-assembled unit? - How does the noise level at the seat relate to pre-cab..more/less/same? Thanks for sharing...would be great to see more pictures |
#14 (permalink) | |
Gold Member
Quote:
Could you provide some pictures of the A/C set-up. I would like to install something like this in my track loader - Cab no A/C 24v system - do they have 24 volt inverters? Is the A/C on the back of the Cab. Thanks very interesting
__________________
Nashville/Hickory Kioti DK55c, Hustler SuperZ, 72 Box Blade, Stihl HT101, International Machines 7ft Mower, Liebherr 631B |
#15 (permalink) | |
Member
Quote:
Yeah thats the reason for building this cab , I have 400hrs on it and its only a year old in june. I didnt want to trade it in until i have paid more on it and can right it off on my taxes this year. Anyways. The glass is in a track i made out of 1/2 angle. The glass pieces are glued into the frame with high tack glazing silicone. I tested one piece with some liquid nails clear and it seems to be holding up good also. FYI , This tractor is used daily about 8-12 hrs moving dirt or mowing properties. Hauled by trailer about 100miles a day or more. Everything is holding up well without any problems. I did have to take the dash out and insulate with foam because of the heat coming off the engine and wrapped insulation around the loader valve .Lots of heat coming off the valve. I will post some pics ,just havent had time. As far as the noise level. Its alot less than with a canopy. Not loud at all. I actually have a amp and Sirus satelite radio that i listen to all day. I have used several cab tractors and its about the same. the roof is insualted and the floor has carpet.
__________________
#16 (permalink) | |
Quote:
Thanks..great project. More pics would be great. Will try to hold off on the hundreds of questions. |
#17 (permalink) |
Member
Well i bit the bullet and bought another tractor . I pulled the cab off i built and traded the MX 5000 in on a cab 6040. The a/c on the Cab i built would in my opinion work fine for someone for personal use. My biggest problem was being to demanding on the setup.I mow commercial and that means daily 10-16hrs a day in 100plus temps. I have read several other threads on here about installing a/c on a cab and using automotive type systems. All i can say is go for it. Dont let negative people or some engineer guru tell you cant do something. If no one ever attempted to try anything you might be sitting in a non a/c house right now. My cab off the Mx 5000 is for sale if anyone is interested. Please fill free to email me. Would be great for a snow blower or for personal use.
__________________
#18 (permalink) |
[quote=FlashPoint]I mow commercial and that means daily 10-16hrs a day in 100plus temps. I have read several other threads on here about installing a/c on a cab and using automotive type systems. All i can say is go for it. Dont let negative people or some engineer guru tell you cant do something. QUOTE]
Thanks for the update ...good thoughts. |
| Thread Tools | Search this Thread |
| Display Modes | |
| About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com |
