#11 (permalink) |
I am about to embark on my own thumb journey, lol. I love the fact that you use whatever you have around to build stuff, cause thats what I do. I found some online to get the basic idea and even called one company. these guys wanted 1800.00 for the mechanical thumb and 3000 for the hydro. one. Im thinking my b3030 really doesnt need a 1800.00 thumb. between the scrap metal, a mig welder, a torch and some redneck engeering i can build this baby for about 30.00 (pins).
good job man, build ya a grade blade to, you will love it
__________________
Kubota b3030, LA 403, BH 75, Kubota ZD326, redneck thumb, grade blade, 07 GMC V-MAX, 08 GMC DEANLI, 18' Car huler, Stihl ms290, stihl combi system, stihl br550 blower, hh130 mig, victor torch, snap on hand tools and cornwell box ect................... |
#12 (permalink) | |
Gold Member
Quote:
Then, you could swith-hit between articulated and not etc.. I choose to weld a long piece on to make sure it stayed on! And didn't look at his till after I was done. For a grade blade, I REALLY need some metel!
__________________
Please resize your pictures before uploading them. Try ImageResizer from Microsoft for free... Image Resizer Thereafter, just right-click an image and choose "resize". It's that easy! NE Oklahoma, ck30 kioti BH w/thumb, Broken FEL, toothbar, box blade. JD 60" brush hog. My Photo's |
#13 (permalink) |
GOOD JOB,I THINK ITS PERFECT.Mine is welded on and im not sorry i did it either.Takes some thinkin doesnt it
?ALAN
__________________
KUBOTA BX-23,LOADED AG TIRES,MECHANICAL THUMB,SALSCO CHIPPER,WOODS LRC60 LANDSCAPE RAKE WITH GAUGE WHEELS,,BUCKET FORKS,QUICK HITCH FOR 3 POINT HITCH,FRONT BUCKET-QUICK HITCH, FARM FORCE 6 FT 3POINT BLADE,MARKHAM TOOTHBAR,TRAILER HITCH FOR BACKHOE, HOMEMADE STEEL CAB,54 INCH PRONOVOST PUMA 3 POINT SNOW BLOWER,WITH HYDRAULIC CHUTE CONTROL |
#14 (permalink) | |
Gold Member
Quote:
![]() And yes, tractoring makes my brain tired... Or at least tractorbynet does.. ha
__________________
#15 (permalink) |
Here is the one I like best.. No welding required on the backhoe.
http://www.tractorbynet.com/forums/b...ighlight=thumb Wedge
__________________
1967 Ford 4000, Box blade, straight blade, FEL, Rake, Bushhog, BH Jinma chipper Last edited by wedge40; 06-06-2008 at 05:04 PM. |
#16 (permalink) |
Wedge,
Thanks for the complement here...... That thumb was the best thing I have on this machine so far as its really useful. Didn't take long to design neither! Craig
__________________
Honda is truly the best on earth, but Kubota is coming a close second! 1971 Whack-a-Mole Champion of Westmoreland County To many toys - not enough time! |
#17 (permalink) | |
Quote:
My first thumb was straight, too, and the subsequent ones all had just a slight curve. I also found that I had plenty of grip with either no teeth, or just a few small teeth.
__________________
See my TBN projects at: http://hometown.aol.com/dkrug/page1.html Kubota B21 rebuild 1 cy FEL bucket custom b/h thumb custom b/h subframe Diesel fuel dispenser Bucket dentistry custom hydraulic b/h thumb |
#18 (permalink) |
at what point do you measure to get your over all length of the thumb ? I looked at mine and I am figuring around 24". some like that bolt on job look real short and some look like they are the same length as the bucket at about 90 degree on the curl. I would think you would want it just slightly longer but i duno
any input would be great, im rounding up metal this week.
__________________
#19 (permalink) | |
Gold Member
Quote:
I originally had the very bottom cap at the end of the channel stick out a bit further than the rest. That also disfigured 4x4's when I pulled them out of the ground. There are times when I wish I had a horizontal piece to fit over the teeth, like when I'm reaching down the side of the dam and plucking small cedar trees. Hard to grab a tree that's only 1" diameter.
__________________
#20 (permalink) | |
Gold Member
Quote:
__________________
| Thread Tools | |
| Display Modes | |
| About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com |
