HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Customization
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 06-16-2008, 05:38 PM   #41 (permalink)
Super Member
3RRL's Avatar
Default Re: My new backhoe thumb
Well, you have that bar that spans the center now, so that is probably good enough. I just put some remnant teeth on my bar for added grip and a cool look. Don't know how much those teeth really add. But nevertheless, they will grip, that's for sure.
On another note, the concern for off center grabs possibly tweaking the jaw could be off set with two turnbuckles instead of one...that is if you find it to be a problem.
__________________
Rob-
...The Older I get...the Better I Used to be...
3RRL is offline   Reply With Quote
Old 06-16-2008, 06:14 PM   #42 (permalink)
workinallthetime's Avatar
Quote:
i really have not noticed a problem, i did actually break one of the mounts at the top of the thumb. I cleaned the area up with the grinder, then added a brace between the 2, problem fixed.
ok back to laying tile, more rain and more mudd, will it ever end????????
__________________
Kubota b3030, LA 403, BH 75, Kubota ZD326, redneck thumb, grade blade, 07 GMC V-MAX, 08 GMC DEANLI, 18' Car huler, Stihl ms290, stihl combi system, stihl br550 blower, hh130 mig, victor torch, snap on hand tools and cornwell box ect...................
workinallthetime is offline   Reply With Quote
Old 07-11-2008, 08:11 PM   #43 (permalink)
here is a couple pics of the "grade blade" i am always talking about. works great in alot of different aplications
ID:	106210  my-new-backhoe-thumb-dsc00159-small-.jpg.JPG
ID:	106211  my-new-backhoe-thumb-dsc00163-small-.jpg.JPG
__________________
Old 07-12-2008, 02:13 PM   #44 (permalink)
Gold Member
Interesting. What all did you say you do with it?
__________________
Please resize your pictures before uploading them.
Try ImageResizer from Microsoft for free...
Image Resizer Thereafter, just right-click an image and choose "resize". It's that easy!
NE Oklahoma, ck30 kioti BH w/thumb, Broken FEL, toothbar, box blade. JD 60" brush hog.
My Photo's
rcrcomputing is offline   Reply With Quote
Old 07-12-2008, 03:57 PM   #45 (permalink)
they advertise them to be the greatest thing to backfill a trench after your done and it works great for that. depending on the angle of the blade you can slide right on top of the grass to put the spoil back in. I have also found it to be really good at cutting sod, the sod will roll up into the bucket into nice pieces. its great for gleaning out ditches, grading an area for a padio or walk, carving into packed clay, cleaning up an area when your done (its like a solid rake).
it just seems vary useful, i built it for my old bx23 and mad it work for the b3030 and built it out of scrap from my toothbar project. last weekend i excavated out for my buddies padio and walk and it performed perfect since we were only shaving the sod off. He was able to take the sod to another area and use it there. I also cleaned his 1/4 mile worth of ditch with it, its not fool proof but i have yet to cut a line with the thing, even his 12 gage sprinkler circuit. managed to run across it 3 times and not cut it.
ohh and also work well for cleaning off the trailer
__________________
Old 07-13-2008, 10:47 AM   #46 (permalink)
Gold Member
Hmm, may have to get a piece of steel and clamp it on for testing. Though I have serious doubts the kioti bucking bronco backhoe with work for this. Even with the moter at the lowest speed, feathering the controls doesn't work really well. Especially the sideways control. Very frustrating. Maybe someone can give me a hint on the side ways control.
Strong backhoe, but I wish it'd get off the steroids once in awhile..
So, I gather that's about 1/4" steel and when doubled, the part that hits the ground is about 1/2" or did you sharpen it to a cutting edge?
__________________
My Photo's
Old 07-13-2008, 10:58 AM   #47 (permalink)
Willl's Avatar
Use the thumb Luke.
__________________
My PhotoBucket
If you can read this, your 'Ignore List' isn't working.
Willl is offline   Reply With Quote
Old 07-14-2008, 12:01 AM   #48 (permalink)
Gold Member
AchingBack's Avatar
Quote:
Originally Posted by rcrcomputing
Snowboy, at least when I say I have a thumb, you can say "no, I have a thumb!!"
Thanks guys! For all the good comments.
I didn't realize how ugly the thing was till I posted pictures. Thanks for not mentioning it. hehe
But it works!
Ugly? Why a blind man would be glad to see that thumb. You might even rent it out to lazy hitch hikers.
__________________
I thank God for these gifts: Mahindra 2615 HST w/loader, Markham tooth bar, Brush Hog SQ60 rotary cutter, Brush Hog 3507 angle blade. Rankin loader mounted forks, 2 DR field and brush mowers
"Blame no one. Expect nothing. Do something".
-- Unknown
AchingBack is offline   Reply With Quote
Old 07-14-2008, 12:51 AM   #49 (permalink)
if i used my fixed thumb to hold the blade it would limit my angle on entry way to much.
the steel i made it from is the scrap from my tooth bar which was made from a worn out cutting edge on a box balde or large wheel loader, i duno which. the piece was allready cut to an edge. i would say its about 5/8" thick and backed up with some 1/4 inch strap i had laying around. For a project that only took about 30 minutes to build it sure has worked well in various situations.
__________________
Old 07-14-2008, 08:55 PM   #50 (permalink)
Willl's Avatar
Quote:
Ya, that is the biggest draw back doing it with the thumb.
Gotcha on the install/uninstall time though.
__________________
My PhotoBucket
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
