HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Customization
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 06-14-2008, 05:44 PM   #1 (permalink)
Member
rhett's Avatar
Default TSC Landscape-Rake Tine Auto-Magic Align
GuglioLS awesome thread = General Forums > Build-It Yourself > Landscape Rake Build got me interested and thinking of a simple "Customization" for my TSC 6' Landscape Rake. The customization allows the spring tines to float and align to the angle of use, at the same time keeping tine spacing at a constant.
The last task I've yet to do is build pivoting straps to keep the tensioner bar at a desired setting. Without them the tensioner bar will always be forced up against the 4" angle allowing maximum spring action. (described on pix)
Parts Used:
2 boxes of 100 ct 5/16" flat washers ($3.95 box of 100 at local hardware)
Qty = ? of 3/8" Lock Nuts ($0.17 ea, I only needed 9 where for some reason they used plain nuts and lock washers in a few spots?)
To Do:
1. Loosen all 3/8" bolts that connect tines to 4" angle. They should be snug but still be turnable almost by hand. (mine are turnable by hand right at snug)
2. Loosen all 3/8" bolts on the tine tensioner to where the nuts can be removed by hand.
2a. 1 bolt at a time add 5 ea 5/16" washers between the tensioner straps, finger tighten nuts. I had 37 to do.
2b. Tighten all the nuts, they should be snug but still be turnable almost by hand. (mine are turnable by hand at snug)
Use:
1. Tines will auto-magically align during heavy forward use.
2. Or Rake raised, you can grab a tine in its curved part and adjust by giving a good tug.
3. Tighten all the 3/8" bolts and there should be no movement if that is desied.
Rhett
tsc-landscape-rake-tine-auto-01_tsc-_6ft_rake_tines-angled.jpg  tsc-landscape-rake-tine-auto-02_tsc-_6ft_rake_washers.jpg  tsc-landscape-rake-tine-auto-03_tsc-_6ft_rake.jpg  tsc-landscape-rake-tine-auto-04_tsc-_6ft_rake_tension_adj_strap.jpg  tsc-landscape-rake-tine-auto-05_tsc-_6ft_rake_ez-hitch_cutaway.jpg
__________________
Yanmar YM1600
5' Finish Mower - 4' Brush Cutter - Post Hole Digger - 6' Landscape Rake - 30" Dirt Scoop - 5' Box Frame Disc's - Tree Grubber - 3 PT Field Crane - PTO Pump w/2 30gal tanks and spray booms
rhett is offline   Reply With Quote
Old 06-19-2008, 08:20 AM   #2 (permalink)
Gold Member
dtd24's Avatar
Default Re: TSC Landscape-Rake Tine Auto-Magic Align
I dont get it. What is it that your customization will do?
__________________
98 JD 1070 (573 hrs), 440 JD Loader, 8B JD Back Hoe, 5' King Kutter Rotary Cutter, 6' King Kutter Landscape Rake, 7' King Kutter Back Blade, 6' Farm Force Box Blade, Custom Design/Built Grapple, Farm Force PHD w/ 9" & 12" Augers
dtd24 is offline   Reply With Quote
Old 06-19-2008, 10:54 AM   #3 (permalink)
Quote:
it appears to let the tines of the rake swivel to match the direction of travel of the tractor while the take is at an angle
__________________
However beautiful the strategy, you should occasionally look at the results.
-- Sir Winston Churchill
aczlan is offline   Reply With Quote
Old 06-19-2008, 02:07 PM   #4 (permalink)
Reg
Quote:
...and the point of that is.. what ?
I'd guess the windrowing effect is lost.
Instead of having what are effectively many small angled blades you get many small straight blades arranged on a diagonal - - Like, Duhh - so what ?
Reg is online now   Reply With Quote
Old 06-19-2008, 02:09 PM   #5 (permalink)
Member
rhett's Avatar
yes, what "aczlan said
also, what I've found from several days of use with the tines 'floating' (not bolted rigid). the rake does not clog up as bad as before. after several days of use after installing the washers, I've only had to get off the tractor once to clean the rake, and it was very easy to clean. the 'floating tines' do not seem to allow vines, shrubs and such to get tightly entangled, making for an easy clean.
Rhett
__________________
Yanmar YM1600
Old 06-19-2008, 02:32 PM   #6 (permalink)
Member
rhett's Avatar
Quote:
to allow the spring steel to spring at its design.
no, the wind rowing effect is not lost.
anyone could at anytime grab a couple of wrenches and tighten them up so there is no movement. at the least the washers will not allow forced misaligned tines.
why knock something without trying it first?
Rhett
__________________
Yanmar YM1600
Old 06-20-2008, 01:01 AM   #7 (permalink)
GuglioLS's Avatar
Rhett,
Interesting concept keeping the rake tines parallel to the line of engagement. Seems to me your idea has merit eliminating side forces on the tines allowing them to keep their spring action. Keep experimenting and thinking outside the box. You may be on to something here, especially if the tines will automatically line up to the direction of pull regardless of rake angle. I like the fact you reported the tines do not get clogged as bad - how cool is that?
Larry
__________________
I am a bomb technician, If you see me running try to keep up!
GuglioLS is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
