HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Customization
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 06-16-2008, 07:27 PM   #1 (permalink)
New Member
Default Air intake modification ideas?
Our TYM's air intake is located low and near the front of the tractor. When conditions are dry, dusty air is easily drawn into the air intake.
We thought we could add pipe or hose onto the air intake and re-route the air intake back along the side of the engine, through the hood and up to a higher stack.
Does anybody have ideas on how we could do this? We can do simple fabrication.
Wendi is offline   Reply With Quote
Old 06-16-2008, 08:37 PM   #2 (permalink)
slewisma's Avatar
Send a message via AIM to slewisma
Default Re: Air intake modification ideas?
It's been many years since I was a 4X4 pickup modifying youngster but I recall a popular mod back then was a "snorkel" for making 4X4's more likely to survive watercrossings. A little web searching and voila! Have a look here for the general concepts. Need to adapt to the space available for routing and mounting in the TYM but this should give you some ideas:
The Homemade Snorkel for a Bronco
For the TYM, unless you've got some really bizarre uses in mind, you can probably scale this down a bit and keep in inside the hood.
__________________
-Scott
BX24 FEL, BH, 54" Finecut MMM, BXpanded sprayer, forks and BH dolly .... so far.
slewisma is offline   Reply With Quote
Old 06-16-2008, 09:41 PM   #3 (permalink)
Super Star Member
Soundguy's Avatar
Do the snorkel idea, and get one of those dust settling 'hat's for it.. IE.. size the pipe fro a standard sediment bowl.. you can get them at tsc.. etc..
soundguy
Soundguy is offline   Reply With Quote
Old 06-17-2008, 02:10 PM   #4 (permalink)
New Member
Scott, thanks for the PVC snorkel idea. Now to find the air intake hose and figure the best route for the air intake hose and the PVC pipe. (Maybe the air intake hose could come straight up from the air filter canister in the front and connect to the PVC which could run along the center top of the hood towards the back and then up.) Both the hood and side panels need to be removable so the junction between the air intake hose and the PVC would have to mate without actually being permanently connected.
Soundguy, what is tsc? Can I find the website?
Old 06-17-2008, 02:46 PM   #5 (permalink)
slewisma's Avatar
I think he meant Tractor Supply Company by tsc: www.tractorsupply.com
For the snorkel, the only other thought I had was fewer bends = better air flow.
__________________
-Scott
Old 06-17-2008, 03:27 PM   #6 (permalink)
Super Star Member
Soundguy's Avatar
Yep.. If possible go straight fromthe air cleaner thru the hood..
soundguy
Old 06-17-2008, 09:05 PM   #7 (permalink)
Not sure on the TYM but on the jinmas there was/is a mod that unbolts the intake flange mount (4 bolts that takes the intake inlet flange off) rotate the flange over 180 degrees that sends intake hose back towards operator, then with a slight mod of shortening the hose it bends & comes out of side of cowl and right to the FEL to mount the intake air cleaner assy. this would free up access to battery and keep it from sucking hot under hood air. should be several posts on it here and at NYCTOA site.
have to looks & see if you TYM is similar SCMALTS (spelling?) is one who did this I THINK can't remember for sure.
mark m
__________________
I may remember why I went to the other end of the shop, I'm just afraid once I get there I'll forget how to get back! [img]/forums/images/graemlins/blush.gif[/img]
SPIKER is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com
