Spudland_Dave
Ok...heres the deal...working on a diverter setup. I kinda have to use a SPDT switch cause its the only factory switch I could find...working on a DPDT switch which would do away with the need for this post, but having a "Factory Looking Install" Trumps the switch issue..LOL
Here's what needs to happen....
When No Power is applied to the block, the Green Hyd Circuit is "Live" (Off Position on switch)
When I want to use either the Yellow or Blue Hyd Circuit, I need to also energize the green which shuts that port down.
How?...I Realize the diagram is unfinished...
