Page 1 of 3 123 LastLast
Results 1 to 10 of 26
  1. #1
    Veteran Member canoetrpr's Avatar
    Join Date
    Aug 2005
    Posts
    2,382
    Ontario, Canada
    Kubota M7040 cab/hyd shuttle - current, Kubota L3400 - traded
    Default Opinions on box blade modifications
    I'm ready to take on my first implement modification project having gotten to the point where I think I can weld well enough to do something simple.
    My box blade is the kind that has a hinged rear blade and I want to set it up so that the rear blade could be fixed optionally. Others have noted that a fixed rear blade works well for final grading... figured I might as well have the option.
    There are some box blades that come from the factory so that the rear blade can be adjusted to either be fixed or not. I've never seen one like this. If you have one, can you describe to me what the mechanism is that either locks the blade in place or allows it to move?
    I have attached a picture of my box blade. My current thought is to weld a 3/8" plate to each side so that it over hangs by a couple inches off the rear. Then I would drill 2 3/4" holes into each of these side overhangs through which I can insert two 3/4" pins.
    The pins alone might do the trick but the rear blade is not shaped exactly straight (unless one 3/4" pin would do it).
    Thought was to cut another 3/8 piece for each side which would be loose and would fit up against the rear blade. It would also have two holes to align with the welded on side plate, through which the 3/4" pins would go.
    Not sure if one 3/8" piece on each side supported by two 3/4" pins will adequately hold the rear blade in place.
    Your thoughts are appreciated.
    P.S. Rob - bet you will have some good ideas on this one. You put me up to considering rigging something up to fix the rear blade when necessary
    Current: Kubota M7040 cab, hydraulic shuttle, Kubota M20 loader (made by ALO), LandPride RCR1872 rotary cutter, Horst bale spears & forks, Woods HB72 box blade, Kodiak 7' rake, Walco cultivator, chain harrow, Meteor 74" pull style blower
    Traded: Kubota L3400, LA473 HST (300 hrs), and various attachments
  2. #2
    Join Date
    Aug 2005
    Posts
    2,382
    Ontario, Canada
    Default Re: Opinions on box blade modifications
    Oops.. here's the blade.
    Attached Thumbnails Attached Thumbnails Opinions on box blade modifications-img_5233-jpg
  3. #3
    Gold Member actionaj's Avatar
    Join Date
    Oct 2007
    Posts
    427
    Southern Illinois
    BX2350
    Need more pics. one with the door open.
    BX2350
    FEL, RCK54 MMM, 4' Farm Star BB, 5' Farm Star RB, 5' Rake
  4. #4
    Super Member
    Join Date
    Sep 2000
    Posts
    6,595
    buy some 3/8" thick by 2" angle iron. Bolt it on the edges so it holds the edge down. The bolts will go from outside to inside. Inside the box, weld nuts so you only have to loosen / tighten from the outside.
    Align the angle. Clamp it in place. Drill the holes thru the angle and the box. Remove the angle. Grind off the paint on the inside. Assemble the angle with bolts & nuts. Protect the bolts so the weld slag doesn't freeze them. Weld the nuts. wire brush off the burnt paint, prime, paint, photo and admire.
  5. #5
    Gold Member
    Join Date
    May 2006
    Posts
    478
    Central Illinois. No, not Chicago.
    IH 404, Cub GT 2554
    Quote Originally Posted by john_bud
    I have a similar blade and this was almost exactly my thought. I wasn't going to weld the nut on the inside though if it was at all possible to get to the area to remove it. On my blade it might take 2 1/2" or 3" angle to make the dimensions work.
    1962 IH 404, 2006 Cub 2554
  6. #6
    Join Date
    Aug 2005
    Posts
    2,382
    Ontario, Canada
    john_bud - glad I came and asked here!
    In bed right not but I will check the blade tomorrow. Pretty sure that area I would have to drill would not be terribly accessible from the inside of the box blade even to weld on nuts.
    That said, I'm thinking of a simple modification to your idea. Welding on a 3/8" piece at each end jutting out of the back two to three inches, so that I have something to drill that I can access. Bolting on the angle iron except reverse to the way I'd have to do it as per your description.
    Now that I think about it, I have some 1/4" thick angle iron about 3-4" sitting in the shop that I picked up at a scrap yard to practise welding. I think it might work perfectly if 1/4" won't be too weak. If it is - well it was scrap anyway, and I'll go replace it with something stiffer when it bends up!
    Thanks again!
  7. #7
    Join Date
    Aug 2005
    Posts
    2,382
    Ontario, Canada
    john_bud - silly question from a welding newbie. How does one "protect the bolts so the weld slag won't freeze them"?
  8. #8
    Gold Member
    Join Date
    May 2006
    Posts
    478
    IH 404, Cub GT 2554
    Quote Originally Posted by canoetrpr
    If you use loose nuts you access them from the bottom. Just put it on the 3 point and lift it up. If you want to weld the nuts on then set the blade on its endplate
    Put a bolt in them that sits flush with the nut face before you start welding. Remove it before the nut cools completely.
    That said, I think you'll be disappointed with nuts welded on. The welding heat turns your nice grade 5 or grade 8 nuts into something that's softer than hardware grade fasteners...
  9. #9
    Join Date
    Aug 2005
    Posts
    2,382
    Ontario, Canada
    Looks like welding nuts or putting hole in the side plate won't work out for me. The area is inaccessible even from the bottom. This is the area between the two (front and rear) blades and there isn't a way to get to it on the other side.
    However the modification to john_bud's idea will work. I'll weld up a 6" by 3" 3/8" plate so that 3"x3" juts out behind the side plate. I'll drill that and hook the angle iron to that.
    Thanks!
  10. #10
    Super Member
    Join Date
    Sep 2000
    Posts
    6,595
    Glad to help.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
