#1 (permalink) |
Elite Member
We've got an International 880 (or was it 980?)
Primarily use it to pull a big mower. Up to now, been using the box blade (5') behind the smaller International 444. Been debating on getting a larger, heavier box blade and putting it behind the 880. If I did so, I think I'd want to have some bells/whistles in that I'd like to have a TNT type setup. If memory serves me, this machine currently has two sets of outlets on the back. I say it that way because I think it has FOUR controls next to the seat. Fairly new machine to us and I've never counted the outlets on back. So.... if I only have two operating pair of outlets on the back what all would I need to do to get a TNT system and more importantly, how does one know what size cylinders to get??? Also...don't I recall some kind of TNT setup with a checkvalve in it so the box on the back won't bleed down? If so, would that setup be contained in the cylinder? |
#2 (permalink) |
Member
All your top n tilt needs here> Carter and Carter Machinery, Hay Equipment Headquarters
Just a short drive from Knox Co. J |
#3 (permalink) |
Yep, C&C can fix you up. They have cylinders with check valves on them. With two sets of remotes you can have top & tilt, Just not hydraulic scarfiers.
The heavier the better on the BB.
__________________
YANMAR FX42d, Koyker 155 FEL, ROPS w/Canapy, Top & Tilt Gearmore BS w/ Hydraulic Scarfiers. Loaded R4 Industrial Tires, Princess Auto BH w/ Subframe. Boom pole. Pallet Forks. |
#4 (permalink) |
Elite Member
I'll ask another question that might be best for someone like them. (I called them and between being on hold, had another phone call that I had to get so ended up hanging up on them while on hold)
Anyways..... on looking around their website, I noticed a joystick... So.... Is it possible to take one of my pair of remotes, plumb "something" into them that would then power up a joystick and allow this joystick alone, to control both the up/down and forward/back of the side & top links? That would then leave my other set of ports for perhaps some hydraulic scarifiers. I really don't like to climb up/down all the time for these minute changes so I'm trying to find out what all I CAN do, then of course, how much, before I decide what I really want to do... make sense? |
#5 (permalink) |
Richard, yes I think that would work, however, if you study your remotes and the plumbing I think you could easily put one more set on for Hydraulic Scarfiers. Good luck there is probaly someone who can tell you how to do it.
I can't without seeing it.
__________________
#6 (permalink) |
Super Member
CCM is indeed your best bet especially if you want the DPOCV on them. They are great.
That joystick valve, I'm pretty sure, needs to be plumbed into your hydraulic system. It's NOT intended to plug into your rear remotes. It's another valve like the one that controls your rear remotes. Plumbing into your system is a bit of work but not that hard to do. Once plumbed into your system, that joystick valve controls the top and side link like you envisioned. Then, that leaves your rear remotes open for any other hydraulic application you have. To be sure you get what you want and the right components, you need to talk to them, specifically Mark. He will need some information about your tractor and then set you up accordingly. Mark is a frequent poster here on TBN.
__________________
Rob- ...The Older I get...the Better I Used to be... |
#8 (permalink) | |
Epic Contributor
Quote:
The first photo shows the two cylinders I put on my B2710, the second photo shows the hydraulic valve, and the third and fourth photos show how my box blade could be adjusted forward and back. And of course it could also be tilted side to side.
__________________
#10 (permalink) |
Epic Contributor
Yes, you can do just one or the other instead of both. I know the top was, by far, the one I used the most and I think that's true for most people. But depending on the jobs you need to do, the side tilt might be the one you'd use the most. Naturally, we tend to think first of using the hydraulics to adjust the angle of implements on the 3-point, but it's also useful when hooking up those implements. You can adjust the length of the cylinders instead of man handling the implement to get it lined up exactly.
__________________
| Thread Tools | |
| Display Modes | |
| About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com |
