Results 1 to 6 of 6
  1. #1
    Silver Member Hookblock's Avatar
    Join Date
    Nov 2007
    Posts
    201
    WI
    JD 4310
    Default Rear blade weight
    I took everyones advice about adding weight to box blade and it works great for what I need. So then how about adding weight to a rear blade, I did and it is much better, and added a stand. I don't have pictures of the box blade yet.
    Attached Thumbnails Attached Thumbnails Rear blade weight-img_0863_1.jpg   Rear blade weight-img_0867_1.jpg   Rear blade weight-img_0870_1.jpg   Rear blade weight-img_0871_1.jpg
  2. #2
    Silver Member George in Spokane's Avatar
    Join Date
    Jun 2006
    Posts
    109
    Default Re: Rear blade weight
    I don't understand what that extra piece to the upper 3 pt is for. Is it a brace or does it support the weight?
    How much weight did you add?
    2008 Kioti CK-35 w/ FEL, HST, toothbar, R1, RimGuard, 2" wheel spacers
    1956 Ferguson TO-35
  3. #3
    Join Date
    Nov 2007
    Posts
    201
    WI
    JD 4310
    It's a brace, I had to cut the original one out to put the weights on. As far as the weight, they are old elevator weights about 275lbs. with the two of them about 550# With the loader and forks I am finding adding weight to everything helps
  4. #4
    Super Member
    Join Date
    Sep 2000
    Posts
    6,358
    Weight rules for ground engaging equipment.
  5. #5
    Elite Member johnk's Avatar
    Join Date
    Jun 2003
    Posts
    2,531
    western NY
    Kubota GST Grand L3130 w/ 723 loader, Ags
    I welded a couple culivator tines to the back of my BB and slid some suitcase weights on. It definitely works better.
    Attached Thumbnails Attached Thumbnails Rear blade weight-cabin-8-20-2008-068.jpg
  6. #6
    Join Date
    Dec 2004
    Posts
    93
    Central Florida
    JD 4310
    Quote Originally Posted by Hookblock View Post
    I like the weights and I have also added a stand to my blade and landscape rake but with the quick hitch i never have to get off the tractor and have forgotten to lift the stand up and break it as soon as I drive away.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
