Results 1 to 10 of 28
09-11-2008, 05:09 PM #1Super Member
- Join Date
- Jul 2005
- Posts
- 5,151
- Location
- Idaho
- Tractor
- Massey Ferguson 1215, Toro 266-H, Pennsylvania Panzer, Case 444, Craftsman 14/6
Air Compressor 12 volt pressure switch
At some point I'd like to make an engine driven air compressor. How are engine driven compressors pressure regulated?
I'd probably drive the compressor with an electric PTO clutch. I figured that I could use a 12 volt pressure switch that would turn the clutch on when the pressure drops below a set point and then turns it off when the pressure builds sufficiently. Problem is I'm not finding a lot of 12 volt pressure switches.
Is there some other way that the engine driven compressors regulate their pressure?
Could I just use a 120 volt pressure switch?Last edited by Iplayfarmer; 09-11-2008 at 05:11 PM. Reason: Forgot something
From now on I will only buy cars that are a silver/grey color. Then I can make all body repairs with Duct Tape.
09-11-2008, 08:08 PM #2
Re: Air Compressor 12 volt pressure switch
This switch Configuration Results is just a electro-mech that won't care what voltage it gets.
09-11-2008, 08:52 PM #3Elite Member
- Join Date
- Oct 2004
- Posts
- 2,894
- Location
- limerick pa lycoming county pa
- Tractor
- kubota bx23
they continue to run compressor and have and unloader in the discharge line or
like granger #4TK14 it is the control I used to change my electric generator to gas to build my cabin (off grid) with a 8 hp gas engine
On the big construction compressors they have a control that holds the intake valve open exhaust valve is a check valve. and the air goes in and out intake valve and dosen't compress.
tommuIf it ain't broke we will help you brake it
If it is broke we will help you get it fixed!
09-11-2008, 09:23 PM #4Elite Member
- Join Date
- Sep 2006
- Posts
- 2,761
- Location
- Fairfield, PA
- Tractor
- JD 3020, JD 4230, JD 7410, JD 2440, MF 750, NH LS170
Wired properly you can use most any electromechanical pressure switch with the correct pressure setting. Just don't run the main power to the compressor through the switch, run it through a relay. Not all pressure switchs are rated for high current draw.
09-11-2008, 09:32 PM #5Platinum Member
- Join Date
- Jun 2006
- Posts
- 500
- Location
- 20 miles southeeast of downtown Sacramento
- Tractor
- Kubota BX23
Kubota BX23, BT600 BH, LA210 FEL, Maschio L125 tiller, Gearmore BB 20-48 BB, King Cutter 6' rear blade, Homemade PHD, Brinly BST-50 broadcaster, ? 6' cultipacker, log & chain drag.
09-12-2008, 12:16 AM #6
09-12-2008, 01:17 AM #7Super Member
- Join Date
- Jul 2005
- Posts
- 5,151
- Location
- Idaho
- Tractor
I was hoping that a few people would chime in that I could just use a 120 volt switch like a well head type switch.
Wouldn't the well head switch handle plenty of current without having to go through a relay.From now on I will only buy cars that are a silver/grey color. Then I can make all body repairs with Duct Tape.
09-12-2008, 07:56 AM #8Gold Member
- Join Date
- Nov 2006
- Posts
- 391
- Location
- Barossa Valley, South Australia
- Tractor
- Duetz DX3.70, Fendt 305LSA,260S & 205P,Kubota B6100E & 3 x B5100E & RTV900, Caterpillar 428C
Yes you could use a 120V pressure switch to operate a magnetic clutch, without a relay.
I used a 240V pressure switch to operate a 12V magnetic clutch that draws 4.7 amps.
Was warned to use a relay as the greater 12V current could cause the contact points in the pressure switch to burn.
Decided to try it without the relay and it's now done two pruning seasons of operating a compressor, each season about 16 - 17 weeks and about 54hrs a week.
09-12-2008, 10:33 AM #9Super Member
- Join Date
- Jul 2005
- Posts
- 5,151
- Location
- Idaho
- Tractor
09-12-2008, 03:18 PM #10
