Idea,Design and fabrication
   / Idea,Design and fabrication #1
4shorts
Elite Member
Bay Roberts, Newfoundland
Kubota 5740,BX25D
Everything starts with an idea and today was no different. My head is full of ideas and the wife says I'm nuts and she's probably right.
Anyway my new Kubota Grand 4240 had this tube on the loader attachment. I said to myself that seemed to be a terrible waist of space and seeing I needed a place to put a tow sling I decided to use that space for it.
I had to have some way of capping the ends of the tube so this is what I did. It was all made out of scrap aluminum. It was machined and then Tiged and machined again. I wasn't to particular about the appearance of the weld because I knew I wanted to machine it anyway. The O rings were used to keep the caps in place but the grooves had to be machined just right or they would be either to tight or to loose. After that was done the parts were etched primed and painted.
   / Idea,Design and fabrication #3
Very impressive workmanship.
Eddie
   / Idea,Design and fabrication #4
You should consider selling those and make a few $$$.
   / Idea,Design and fabrication #5
I love it when a guy does a perfect job...great work!
Now, be sure to post your pics as clickable thumbnails for us slow connection guys.
Thanks,
   / Idea,Design and fabrication #6
Excellent, I have the same crosstube on my Deere's loader.
Plus if you store your tractor outside, bees and wasps will be less likely to use the tube as a nesting site.
Thanks guys. I wanted to try and do the mods I've done without actually altering the tractor. As with the light bar and these end caps I've only either used the tractors existing hardware or in this case it's just a push and pull and no damage to the tube. Glad you all like it and I'll be sure the next time to use the thumb nail system :) Appreciate your comments
   / Idea,Design and fabrication #9
Now thats a job!! I was reading replies wondering how does it hold in - than scrolled back up and noticed those 2 O-rings. Tip of the hat to you, sir, it is great to see man made perfection!
   / Idea,Design and fabrication #11
Nice! I can think of alot of stuff to put in there!
   / Idea,Design and fabrication #12
Nice job. I like how you used the shear to cut the circular end plates cool.
   / Idea,Design and fabrication #13
Someone else had the same thought. My new Mahindra 5525 has the ML250 FEL built by Buhler and distributed by BII Fargo, Inc. They use that tube to store the two legs used to support the FEL when its detached from the tractor.
You can see one of the end caps on the tube and one of the brackets on the far FEL arm for a support leg.
   / Idea,Design and fabrication #14
Very nice work, SHORTS! (Not just one O-ring...2 O-rings!)
Interesting front wheel fenders you have there. I have never seen
these on a tractor. You must drive pretty fast.
Thanks my friend. I've got the sports model which is super fast :D I haven't seen to many around with fenders. They came with the tractor. Appreciate your kind words guys.
Hey flusher. How does your caps work? Interesting indeed.
   / Idea,Design and fabrication #16
I can think of a couple of times where front wheel fenders would have kept me from getting mud in my eye so to speak. Are they stationary, or do they pivot with the wheels when you make a turn?
   / Idea,Design and fabrication #18
Just looking at your tractor again, boy that is a clean machine!
Is it a showroom tractor?
:D I like the french bread Idea. They don't sell it around here because no one speaks french :)
The tractor looks clean because it's new. well it will actually only be used for snow clearing and may never see a dirt road. I attached a picture of my old 1993 GMC truck that was taken a few months ago. that truck has plowed snow every winter for 13 years and is in perfect condition with the orginal paint so I tend to keep everything clean and maintained.
The front fenders are mounted to the steering knuckle and turn when the wheels turn. I think it was a nice thought for Kubota to add them. Enjoyed the comments guys. Thanks!
PS. The Kioti decal was added for a bit of fun. I almost purchased a Kioti but the Kubota won out.:D
2021 CATERPILLAR 730 OFF ROAD DUMP TRUCK (A60429)
2021 CATERPILLAR...
Bobcat MT85 (A60462)
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2014 Chevrolet Silverado 1500 Pickup Truck (A59230)
2014 Chevrolet...
2015 Toro Z Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2015 Toro Z Master...
2013 HAM 289I-30 8 WHEEL PNEUMATIC ROLLER (A60429)
2013 HAM 289I-30 8...
