joes_427_vette
- Joined
- Aug 10, 2004
- Messages
- 1,268
- Location
- Midwest
- Tractor
- IH Cub Lo Boy, 955 John Deere , TC 55 DA New Holland, Bolens HT 20 and 1456
I bought a new old stock 1996 Finn ( ATI manufactured ) power rock rake. The only revision I want to make is it is fixed at 15 degrees to the left by the bolted on hitch assembly. As the mount is welded to the frame I torched the long angle brackets off, ground the base smooth and engineered a base that would include a pivot. If my plan doesn't work the torch is nearby and a second go around will be necessary.
This unit weighs approximately 1000# with the second roller attached. The local steel yard will see me come and go several times.
If anyone has some suggestions I would appreciate the feedback. This is an interesting project and has more planning than I imagined. I wish the designer would have made provisions for this at the build date as a fixed one way offset doesn't work real well in both directions on a hillside.
