Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 37
  1. #11
    Super Member 3RRL's Avatar
    Join Date
    Oct 2005
    Posts
    6,825
    Foothills of the Giant Sequoia's, California
    55HP 4WD KAMA 554 and 4 x 4 Jinma 284
    Default Re: EZ-HITCH
    Quote Originally Posted by EZ-HITCH View Post
    As a rule all customers receive a tracking number from the USPS when the Priority Mail label is purchased. The reason Mr. Wentworth did not receive the tracking number was due to a error on my part. I entered his email address into the form incorrectly. I have refunded the shipping cost to Mr. Wentworth for the EZ-HITCHES and the Spreader Bar. As always customer satisfaction is my number 1 priority!
    Jerome,
    That is very admirable on your part.
    You are a stand-up top notch guy in my book!
    Rob-
    Rob-
    ...The Older I get...the Better I Used to be...
    Member of the Month
  2. #12
    Veteran Member jimmysisson's Avatar
    Join Date
    Jul 2005
    Posts
    2,344
    W.Mass
    1993 NH 2120 (the best), 1974 MF 135 (sold, but solid), 1947 Farmall A (bought, sold, bought back, sold again), 1956 MH50 lbt (sold, in 1980, darn it)
    A Second (or Fifth) for Jerome and his hitch. It won't fit EVERY implement, but most, and it doesn't extend the implement further from the tractor. Good product, good outfit.
    Jim
    "Anything worth doing is worth doing slowly" Mae West
  3. #13
    Gold Member nunyabinis's Avatar
    Join Date
    Nov 2008
    Posts
    320
    The Outer Limits
    Deere
    I like this setup. I'm thinking seriously about ordering a set of these then using my plasma cutter to cut the actual hitching section off of the tubing then welding the hitching section to the top of my lift arms. That way I can use either the normal hitching method or the quick hitch without removing the quick hitch.
    Thoughts?
  4. #14
    Bronze Member EZ-HITCH's Avatar
    Join Date
    Aug 2007
    Posts
    70
    Shepherdsville, Kentucky
    Kubota L4200 GST CAB
    There is no need to do that, we sell just the "J-Hook". It can be ordered from the carterandsonsllc.com web site. You can always call me at 502-376-1435 if you have ANY questions.
    Jerome
  5. #15
    Join Date
    Nov 2008
    Posts
    320
    The Outer Limits
    Deere
    I don't see just the "J" hook on the website. Do you have a link?
  6. #16
    Join Date
    Aug 2007
    Posts
    70
    They can be found under the product catalog tab with the other Cat.1 items.
    Here is a direct link to the page. Sorry for the confusion, the hooks had been taken down by mistake, but they are back up now.
    PRODUCT CATALOG
  7. #17
    Gold Member gordyy's Avatar
    Join Date
    Feb 2009
    Posts
    376
    North Dakota
    cub cadet yanmar sc2400 Kubota F2560
    just ordered a set after fighting with my new tractor and my boxblade they were dropped off by my son and the bb was left in a very unlevel area what a pain
  8. #18
    Join Date
    Aug 2007
    Posts
    70
    Gordy,
    Thanks for the order! You should be receiving your hitches VERY soon. If you have ANY questions, comments or issues; please don't hesitate to contact me.
  9. #19
    Join Date
    Jul 2005
    Posts
    2,344
    W.Mass
    I just want to clarify what I posted earlier about not fitting every implement. My Gannon box has heavy steel plate on both sides of the pins. The plates are closer together than the length of the pin that holds the EZ Hitch to the 3-pt. arms. I had tried the EZ on a couple other implements I own and it worked perfectly. So, I cut the pins shorter and welded washers onto them. No lynch pins, no problem fitting into the box blade (and my winch, also), and I never remove the EZ Hitch. I could grind off the welds if it became necessary.
    Jerome was helpful throughout, and the hitch is EZ to use. Highly recommended.
    Jim
    Attached Thumbnails Attached Thumbnails EZ-HITCH-img_4867-jpg   EZ-HITCH-img_4897-jpg   EZ-HITCH-img_4907-2-jpg
  10. #20
    Join Date
    Nov 2008
    Posts
    320
    The Outer Limits
    Deere
    I just ordered a set for a standard Cat 1 - 2 5/8".
    I checked all my implements last evening and it should work on all of them.
    I can't wait!!!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
