bandit67
- Joined
- May 27, 2004
- Messages
- 1,588
- Location
- Lake Hartwell, SC
- Tractor
- 2012 B3000 HSDCC 2020 Z251 Zero Turn
Last year I upgraded to a Kioti CK25HST and it also had a Sims cab already installed. I was totally disappointed in this cab. The doors did not fit or close properly, the cab was floor mounted and the whole cab would jump around violently and almost take the floor off with it in the process plus I could not see anything around me due to the sheet metal panel design and small rubber mounted windows. I saved the door latches, heater, roof panel and one wiper motor and started from scratch to build a whole new cab. This one is rubber mounted to solid parts of the tractor, does not move at all during operation of the tractor and I can see what am doing. Best of all the doors fit and no water enters the cab.
From the pictures, it looks like you did a beautiful job rebuilding that cab. Looks like a well manufactured cab now, which is more than I can say for the Simms version that was on it before.
