Page 7 of 8 FirstFirst ... 45678 LastLast
Results 61 to 70 of 79
  1. #61
    New Member
    Join Date
    Feb 2011
    Posts
    1
    Default Re: Diesel garden tractor pulling
    hi yes i do what u do but i run a 3cy yanmar diesel with nos propane and water and i have a 2inc turbo
  2. #62
    Member iternawheel's Avatar
    Join Date
    May 2009
    Posts
    36
    MidWisconsin
    1976 Wheel Horse A-100 customized to International 1086
    I am building a diesel puller right now and was wondering how to make the kill switch for the rear of the machine. i think a guillotine shut off would work best but i am unsure how to make it any pics you guys have would be great.
  3. #63
    New Member
    Join Date
    Jan 2011
    Posts
    2
    482IH Briggs 3cyl TDI
    I use a trailer brake break away switch hooked in line with my fuel shut off solenoid
    HOLD MY BEER WHILE I SMOKE THIS DEERE
  4. #64
    Join Date
    May 2009
    Posts
    36
    MidWisconsin
    i dont have a fuel pump it is gravity feed from the tank to the injection pump.
  5. #65
    Gold Member Bigkrank's Avatar
    Join Date
    Jan 2009
    Posts
    319
    NW Ohio
    Quote Originally Posted by iternawheel View Post
    Adapt one of these to front of your turbo inlet. Spring load it. Run a choke cable with a ring pull on it from the rear up to it and run it thru the hole.
    If you ever put an electric pump on you will have to add a power disconnect to the same ring. You will eventually need an electric pump that pushes 40psi when you make power so be prepared. Last thing you want to do is stick a plunger. Put an easy to get to shut-off valve on the fuel line as close to the injection pump as you can also.
    McMaster-Carr
    Diesel garden tractor pulling-1-09-8-jpg
    Diesel garden tractor pulling-1-09-12-jpg
    Several garden tractor pullers
    Kubota B2630
    Kubota ZD28
    Ford 655D backhoe
    Bobcat T190, various attachments
    Numerous Farmalls
  6. #66
    Join Date
    May 2009
    Posts
    36
    MidWisconsin
    thanks i think i will build one though. i am not workin so money is tight but i have the material to build one thanks for the link though.
  7. #67
    moe7404
    Guest
    true pulling tractors are totaly cool. when i was in the army we would spike diesel fuel with gasoline in a 5 ton wrecker. we would blow the 2 1/2 tons in the weeds . also we cranked the tire pressure up to 100-110. my o my i beleave i remember that far back.
  8. #68
    Join Date
    May 2009
    Posts
    36
    MidWisconsin
    Here are a few pictures of my puller that im workin on. hope you enjoy.
    Attached Thumbnails Attached Thumbnails Diesel garden tractor pulling-dsc00873-jpg   Diesel garden tractor pulling-dsc00884-jpg
  9. #69
    Join Date
    May 2009
    Posts
    36
    MidWisconsin
    YouTube - Project Little Chooch
    Here is a link to a video of my motor running. no turbo on it though.
  10. #70
    New Member
    Join Date
    Mar 2011
    Posts
    1
    N/A not yet
    i used to pull diesel pickup class and the hobby has gotten so competative and expensive i cannot afford to play anymore so since im a hardcore diesel fan i am going to build one of these tractors and return to the track i have found a d600 series kubota that i will b purchasing any tips or tricks would b gladly appreciated as far as drive line gearing performance parts for the kubota rods cams pistons etc. also bigkrank wat do u charge to build a cub rearend for a customer prolly need just a mild one to start out with but im not for certain and also how are u connecting the kubota to the cub transaxle thanks for any info one might have
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
