09-25-2009, 01:43 PM
#11 (permalink)
| | Elite Member
| Re: Telescoping hydraulic cylinder 4 dump trailer Here is my hair-brained scheme. You could simulate a telescoping cylinder by connecting two cylinders together. Put the rams going opposite directions and tee off of your lines. I'll see if I can find a minute to sketch up the idea and post it.
__________________ If necessity is the mother of invention, laziness is the father. |
09-25-2009, 02:03 PM
#12 (permalink)
| | Elite Member
| Re: Telescoping hydraulic cylinder 4 dump trailer Here is the sketch...
Reason: add image
09-25-2009, 02:36 PM
#13 (permalink)
| | Super Member
| Re: Telescoping hydraulic cylinder 4 dump trailer I never thought of that, but I wonder on the stress it would put on the cylinder end caps, etc. For light work that might work.
__________________ J.J.
When I works, I works hard. When I sits and thinks, I goes to sleep.
Git er done, if-fen you want to.. |
09-25-2009, 03:35 PM
#14 (permalink)
| | Elite Member
| Re: Telescoping hydraulic cylinder 4 dump trailer Quote:
Originally Posted by J_J I never thought of that, but I wonder on the stress it would put on the cylinder end caps, etc. For light work that might work. | I'm sure there are ways to improve on the idea. You could even put a "S" shaped piece between the cylinders that fits the clevises and takes the stress. You could also build a box of sorts that the bases fit into.
That's what brainstorming is all about. Everyone throws out their mediocre ideas, and hopefully a superior idea is born in the midst of it all.
09-25-2009, 03:38 PM
#15 (permalink)
| | Member
| Re: Telescoping hydraulic cylinder 4 dump trailer To me the liner idea seems the easiest. Is the trailer to large for a pickup liner? They are not as popular now and can be picked up cheap.
Dean
__________________ Kubota 3540, LA724 FEL, Woods 72" BB, Bobcat 42" forks, Crocodile 6' RM, homebuilt Grapple Brush Bucket, IH 7' Sickle mower, homebuilt dump trailer |
09-25-2009, 04:04 PM
#16 (permalink)
| | Platinum Member
| Re: Telescoping hydraulic cylinder 4 dump trailer The liner is the best idea. You also have to consider how tippy it gets when you get it up high in the air and the material doesn't slide out. I have seen semi trailers full of gravel get a little tippy and that looks like it could get ugly in a hurry. |
09-25-2009, 05:03 PM
#17 (permalink)
| | Super Member
Originally Posted by Iplayfarmer Here is the sketch...  | I think you will bend the rods with that setup-unless they are super big.
__________________ JD 4110HST
FEL, 60" MMM, 60" Rear Blade, Ballast Box, I-Match, #380 Snow Plow, FEL Forks, Goossen 3PH Chipper/Shredder, Markham LD-48 Grapple, Trac-Vac 854 and much more "stuff"
JD 4x2 Turf Gator
Some of my projects/adventures are posted in my Picassa Web album. |
09-25-2009, 05:10 PM
#18 (permalink)
| | Elite Member
Originally Posted by kennyd I think you will bend the rods with that setup-unless they are super big. | The other option is to put the cylinders side by side vs. one on top of the other. You'd have to move one or both brackets.
09-25-2009, 05:50 PM
#19 (permalink)
| | Super Member
Originally Posted by Iplayfarmer The other option is to put the cylinders side by side vs. one on top of the other. You'd have to move one or both brackets. | The problem with either setup is the load is not linear to the mounting pins. Look at the modified picture below:
JD 4x2 Turf Gator
09-25-2009, 07:42 PM
#20 (permalink)
| | Veteran Member
Originally Posted by Iplayfarmer Here is the sketch...  | Forklifts use a setup similar to this. They use 2 upright cylinders and one inverted all welded together. That's how a lot of them get the telescoping mast.
__________________ Knowing is not enough, you must apply.
Willing is not enough, you must do.
Bruce Lee |
