Go Back   TractorByNet.com > General Forums > Customization
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 10-05-2009, 01:27 PM   #11 (permalink)
Member
Default Re: === BLADE HOOKS ===
Quote:
Originally Posted by Westendorf-RR View Post
If you weld them on - be sure and keep them INLINE with your loader's arms. It is the strongest location. Welding on outside corners is not recommended - you need to keep the load centered or you could risk twisting your loader, especially if the load shifts.
Good point. Also keeps tractor from tipping.
rayc45 is offline   Reply With Quote
Old 10-05-2009, 01:45 PM   #12 (permalink)
radioman's Avatar
well- having hooks on the blade could be useful for something I guess, but there not loader arms, just the fast attach. I think the top of the front blade should be reinforced and have a SINGLE hook in the center. This would prevent too much twisting and allow him to lift a small branch () and move back with it.
radioman is offline   Reply With Quote
Old 10-05-2009, 04:26 PM   #13 (permalink)
How much lift and strength do the front blade arms have? I'm envisioning a fairly simple structure designed for pushing, not pulling and probably not designed for lifting much more than the blade itself.
Front end loaders are designed fairly heavy to do lifting, pushing, back dragging, etc.
Of course I'm sure it depends on the design of the particular machine.
__________________
Retired with horses
Ken45101 is offline   Reply With Quote
Old 10-06-2009, 08:58 AM   #14 (permalink)
assoon as you started to pull back with the blade, wouldnt it want to "spring over" just s if you hit something hard going forward while plowing?
__________________
2007 Kubota L4400, gear drive, Ag tires, chains all around, FEL, 6ft rear blade, bucket, forks, FEL snowplow, york rake, sitrex mower, Kubota Canopy from mom and dad
2009 Quality 12k trailer, 18'+2' pulled by a
1992 Ram, Cummins power, 5spd, 4x4, utility body, 9' plow
Nothing runs like a yanmar, right?
some zilch is offline   Reply With Quote
Old 10-06-2009, 11:32 AM   #15 (permalink)
Super Star Member
Location: First organized permanent settlement in the northwest territory
Quote:
I will have to put a chain on the blade and hook the other end to something and see what happens.
__________________
Tractors 2003 Kubota BX1500/2004 Kubota Bx23/New- Kubota BX1500
Attachments 60'' Front Blade/48'' Rear Tiller/FEL/Back Hoe /
60'' MMM/Clamp on Forks/48'' MMM
South of Canton Ohio L .B
LBrown59 is offline   Reply With Quote
Old 10-06-2009, 11:56 AM   #16 (permalink)
Elite Member
Diamondpilot's Avatar
Good point.
Chris
Diamondpilot is offline   Reply With Quote
Old 10-12-2009, 05:46 PM   #17 (permalink)
Elite Member
wushaw's Avatar
LB; you will have to install hooks to whatever you have on the ft. of every BX you have in order for this to work as you have planned.
__________________
Kubota L2800HST, Mitsubishi 372, bh75, 45" Agric tiller, 5' home made disk, 42" Bush hog, PHD, 66" Cammond BB.
wushaw is offline   Reply With Quote
Old 10-12-2009, 10:10 PM   #18 (permalink)
Elite Member
Builder's Avatar
Put the hooks a few inches from the bottom or on the cutting edge.
__________________
'07 Kubota M-7040 4x4 tractor: 70HP, Hyd-reverser, 4in1 q/a FEL w/ aux. hyd, Cab-AC, 2 remotes, R-1's, rim gaurd.
'00 New Holland LB115 4x4 Backhoe: 108HP, Powershift. Cab-AC, 4WD/4WS, posi front/rear axles, 4in1 FEL, X-hoe, Aux hammer hydraulics.
'05 Challenger MT285B 4x4 CUT: 48HP HST, Cab-AC, 4in1 q/a FEL w/ aux hyd, 2 remotes, R-4's.
'07 GMC 3500 4x4 Crewcab SLT: Dmax/Ally, utility body.
'92 IH 4800 4x4 Dumptruck: DTA-466 250HP high torque, airbrakes, 7-spd, 12' dump, 33K/56K GCWR.
Builder is offline   Reply With Quote
Old 10-12-2009, 11:08 PM   #19 (permalink)
Elite Member
schmism's Avatar
usually i dont question why some OP wants to make some mod. after all its not my junk so what do i care.
but honestly i cant think of one good reason to have hooks on the front of a snow plow. (although i can think of a ton of bad reasons of why not to)
my suggestion.
dont waste the time and effort to do it.
__________________
Steve - TC33D 4x4 FEL, dual rear remotes with toys
schmism is offline   Reply With Quote
Old 10-13-2009, 05:46 AM   #20 (permalink)
hr3
I picked up an almost new Curtis plow last summer,, It had a hook installed on the top center of the blade,,, It was kinda handy to lift the plow up and put it in the rack for the summer.. Not too sure what else i'll use it for ..
As for the "junk" coment
hr3 is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Page generated in 0.06319 seconds with 9 queries
