10-13-2009, 07:00 AM
#21 (permalink)
| | Super Member
| Re: === BLADE HOOKS === You can put hooks where ever you want, but you will need to lock down the top of the blade to keep it from tilting.
__________________ J.J.
When I works, I works hard. When I sits and thinks, I goes to sleep.
Git er done, if-fen you want to.. |
10-13-2009, 08:27 AM
#22 (permalink)
| | Elite Member
Join Date: Feb 2006 Location: 750 mi. east of a &@$!*#!%
| Re: === BLADE HOOKS === How would the blade tilt if the hooks are on the bottom?
__________________ '07 Kubota M-7040 4x4 tractor: 70HP, Hyd-reverser, 4in1 q/a FEL w/ aux. hyd, Cab-AC, 2 remotes, R-1's, rim gaurd. '00 New Holland LB115 4x4 Backhoe: 108HP, Powershift. Cab-AC, 4WD/4WS, posi front/rear axles, 4in1 FEL, X-hoe, Aux hammer hydraulics. '05 Challenger MT285B 4x4 CUT: 48HP HST, Cab-AC, 4in1 q/a FEL w/ aux hyd, 2 remotes, R-4's. '07 GMC 3500 4x4 Crewcab SLT: Dmax/Ally, utility body. '92 IH 4800 4x4 Dumptruck: DTA-466 250HP high torque, airbrakes, 7-spd, 12' dump, 33K/56K GCWR. |
10-13-2009, 10:09 AM
#23 (permalink)
| | Super Member
| Re: === BLADE HOOKS === Quote:
Originally Posted by Builder How would the blade tilt if the hooks are on the bottom? | Well, of course not, but it is an unusual place for installing hooks, and I would also recommend backing up the weld area with some larger plate.
10-13-2009, 11:09 AM
#24 (permalink)
| | Elite Member
Originally Posted by J_J Well, of course not, but it is an unusual place for installing hooks, and I would also recommend backing up the weld area with some larger plate. | Yes, you're right, it is an unusual spot, but I'm trying to help him, even if it's an "out of the box" type upgrade.
I like your idea of a backing plate. Moldboard skin is pretty thin.
10-14-2009, 12:58 AM
#25 (permalink)
| | Platinum Member
| Re: === BLADE HOOKS === I would install a couple of hooks so you can pass a cable under the blade and hook to. This way the blade is lifted by the cable when you are pulling out the stuck tractor, or when you are backing up to pull something else out. Just remember that the plow is only designed to raise so much before something bends... |
10-14-2009, 06:26 AM
#26 (permalink)
| | Platinum Member
Join Date: Jul 2008 Location: Bay Roberts, Newfoundland, Canada
| Re: === BLADE HOOKS === I put a couple of hooks on my blade SS mount last year when I addapted it to the tractor. I went with the bolt on method. I didn't put them right on the blade due to the trip springs. They came in very handy during the winter to pluck vehicles that were stuck in the snow. |
10-14-2009, 07:57 AM
#27 (permalink)
| | Elite Member
Originally Posted by 4shorts I put a couple of hooks on my blade SS mount last year when I addapted it to the tractor. I went with the bolt on method. I didn't put them right on the blade due to the trip springs. They came in very handy during the winter to pluck vehicles that were stuck in the snow. | That's where I have mine, on the SS plate. I think the OP might have a frame mount plow.
10-14-2009, 11:51 AM
#28 (permalink)
| | Super Star Member
Join Date: Oct 2004 Location: First organized permanent settlement in the northwest territory
Originally Posted by 4shorts I put a couple of hooks on my blade SS mount last year when I addapted it to the tractor. I went with the bolt on method. I didn't put them right on the blade due to the trip springs. They came in very handy during the winter to pluck vehicles that were stuck in the snow. | I knew I didn't invent blade hooks.
__________________ Tractors 2003 Kubota BX1500/2004 Kubota Bx23/New- Kubota BX1500 Attachments 60'' Front Blade/48'' Rear Tiller/FEL/Back Hoe /
60'' MMM/Clamp on Forks/48'' MMM South of Canton Ohio L .B |
10-14-2009, 12:04 PM
#29 (permalink)
| | Platinum Member
Originally Posted by LBrown59 I knew I didn't invent blade hooks. |
I can't credit for them either  |
10-14-2009, 12:06 PM
#30 (permalink)
| | Super Star Member
Originally Posted by Builder That's where I have mine, on the SS plate. I think the OP might have a frame mount plow. |
Here is another photo of the blade inquestion.
