HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Attachments
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 10-26-2009, 08:59 PM   #1 (permalink)
Default hydro top link
Why is the hydro top links so much more than a regular tie rod style?
Any ideas on adapting the cheaper ones to the ball ends?
__________________
Kubota L3300, M5900 and ford 4500 backhoe
dirt clod is offline   Reply With Quote
Old 10-26-2009, 10:25 PM   #2 (permalink)
zzvyb6's Avatar
Default Re: hydro top link
Good question. I just bought a 6' box blade and I can see why you need a hydraulic link. So why are they 150+ dollars when a conventional tierod cylinder is under $100?
I'm going to put a sleeve in the attachment end to run the 1" hole down to the 3/4" pin for the BB and then weld a top link swivel to the bare rod end of a TSC cylinder. That way I can get the lenght and stroke I need rather than settle for a part that's generally too long. Most H.top-links are 20" contracted.
Note that the $170+ H.top links have check valves to prevent leak down. BFD.
__________________
There is no "I" in team, but there is a "Me" if you want to jumble it up a bit...
zzvyb6 is offline   Reply With Quote
Old 10-26-2009, 11:00 PM   #3 (permalink)
Super Member
kennyd's Avatar
First-You don't want a tie-rod cylinder for a HTL due to the limited room most machines have, a welded cylinder is best and it cost's more.
Second-I think they cost more because of the ball/swivel ends they have welded on, there is just not a huge market for cylinders with these ends-so they sell less units making the cost higher.
You can certainly get a regular welded cylinder and weld the proper ends on if you are qualified to do so...but most are not and happily pay the $$$ for the correct cylinder.
__________________
JD 4110HST
FEL, 60" MMM, 60" Rear Blade, Ballast Box, I-Match, #380 Snow Plow, FEL Forks, Goossen 3PH Chipper/Shredder, Markham LD-48 Grapple and much more "stuff"
JD 4x2 Turf Gator
Some of my projects/adventures are posted in my Picassa Web album.
kennyd is online now   Reply With Quote
Old 10-26-2009, 11:01 PM   #4 (permalink)
I see the top links with no check valves for $200 and even more.
__________________
Old 10-26-2009, 11:02 PM   #5 (permalink)
Super Member
kennyd's Avatar
Quote:
To some it is a BFD...
__________________
JD 4110HST
JD 4x2 Turf Gator
Old 10-26-2009, 11:44 PM   #6 (permalink)
found some cheaper. Any thoughts on these for my m5900 cat 2?
1) https://www.surpluscenter.com/item.a...item=9-7259-12
2) https://www.surpluscenter.com/item.a...item=9-7260-12
3) https://www.surpluscenter.com/item.a...item=9-7261-12
They make these in shorter strokes also.
__________________
Old 10-26-2009, 11:58 PM   #7 (permalink)
Super Member
I went the Surplus Center route, but learned that the cast part on the tractor was too narrow for the SC ball swivel to fit.
I bought the one that fit, and couldn't be happier. Shown before hoses connected, and before painting black.
beenthere is offline   Reply With Quote
Old 10-27-2009, 02:59 AM   #8 (permalink)
mjncad's Avatar
Beenthere:
Your tractor looks like my 4200 with the Surplus Center cylinder. Mine came painted dark gray, so I left it alone. I just wish the rod was 1" diameter instead as the cylinder housing is just a bit big and rubs on my PB & SCV quick-connects if I'm not careful.
Picasa Web Albums - Matt - Top-n-Tilt#
__________________
Measure it with a micrometer, mark it with chalk, cut it with a torch, beat to fit, paint to match, inspect it with a microscope.
Google finally fixed Picasa web albums problems I was having. Latest postings.
http://picasaweb.google.com/mjncad/HydraulicsUpgrades#
http://picasaweb.google.com/mjncad/ToolsPower#
mjncad is offline   Reply With Quote
Old 10-27-2009, 08:09 PM   #9 (permalink)
My first hydraulic top link and tilt cylinders were tie rod cylinders that I welded new ends on.
I later upgraded to the cylinders with check valves. Well worth the extra price in my opinion. These cylinders work SO MUCH better than the tie rod cylinders I had.
No more leakdown and the top link holds its position much better when under load boxblading.
I'll take the welded cylinders with checkvalves hands down anyday.
__________________
Vince,
Kioti DK 35/Rhino 85 backhoe
John Deere 850 72" MMM
Hustler Fastrak
DK35vince is offline   Reply With Quote
Old 10-29-2009, 03:53 PM   #10 (permalink)
TTTTTT's Avatar
I just got a hyd toplink that I have plugged into one of my rear remotes. I don't know how i did without it. It is fantastic for what you were saying , attaching implements, grading. and I just picked up a crane/boom where it helps with that . My valves on my remotes are sensitive so I can feather it for fine adjustments easily. I got mine through Dalton. Cost a little more shipping to Can. but it was worth it. This one does not have a lock valve but my remote valve has a full off detent and so far no leakage past so the cylinder stays where you leave it
Hydraulic Top-Link - Category 1
Crane/Boom
3pt Crane/Boom-With Video - TractorByNet.com
Dave
__________________
DF-354 (Oct.2008), Town Sunny 404 Loader,
Town Sunny 3pt BH -6',
3pt Log Splitter - 26",
8' Snow Plow Blade adapted to FEL,
3 pt 7' Rear Blade,
FEL / 3pt Forks,
Hydraulic Toplink.
3pt Hydraulic Crane
TTTTTT is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.24648 seconds with 9 queries
