#1 (permalink) |
The cup holder on the B3030 is behind the seat .
This location is great for keeping you back muscles loose since you need to pivot your body to reach it. However, I sometimes I just want a drink instead of a stretching routine, so I mounted a new one on the right fender. Vic ![]() |
#2 (permalink) |
Location: Boston & Martha's Vineyard, People's Republik of Massachusetts
nice! More pics on how you did it would be great.
B3030 cupholder is awesome for holding bolts and odds and ends. sux for drinks
__________________
---------------------------------------- Charles Kubota B3030 Kubota M59 w/hydro thumb Neat stuff - ATI Preseeder, Hydraulic PHD, Wallenstein BX62r Chipper, Millonzi Grapple, CA 4n1 Bucket. Delta Hook Rear QA system. Too many other random attachments to list (or to own, per my gf) and a really bad tool addiction. But at least I haven't bought a dump truck or bulldozer. Yet. |
#3 (permalink) |
I had a 4" pvc drain pipe coupling left over from installing new drain pipe from the day before.
I just cut a notch for the cup handle, and a triangle shaped notch in the bottom so it fit against the handrail on the fender. I painted it black and attached it with one screw into the side of the plastic lever housing. The lever housing has thick plastic areas for the fender screws, so I attached it in one of these areas. I'll be trying it out tomorrow morning. For the other side, I think I'll weld something up out of steel rod. Should look better and be fun to make. Vic |
#4 (permalink) |
thats exactly what kubota should have done. nice.
__________________
#6 (permalink) |
Great idea ! Agreed, the factory cup holder is better suited to hold odds and ends. I like the idea of a more convenient and comfortable beer holder (as i prefer to call them).
#7 (permalink) |
Mine has a built-in cup holder in the right fender just before the fender turns down. You can kinda see it in this pic.
__________________
Brian 2007 Kubota L3400 4WD 4L/4H/4R Implements: Ansung 2540 Front End Loader, Continental 5' Bronco Cutter, 6ft. Armstrong Ag Box Blade, 3-PT Quick Hitch |
#8 (permalink) |
I see that you use your ROPS as a towel rack also... Thought it was only me!
mark
__________________
red tractor blue tractor green tractor orange tractor too many impliments to list |
| Thread Tools | |
| Display Modes | |
| About TractorByNet.com | Terms of Service | Advertise | © 2008 TractorByNet.com |
