HOME  DISCUSSIONS  PHOTOS  REVIEWS  CLASSIFIEDS  DEALERS  STORE
Go Back   TractorByNet.com > General Forums > Customization
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 11-05-2009, 07:38 PM   #1 (permalink)
Couple of Achers's Avatar
Default DIY - 3rd function joy stick - kind of
After pricing a 3rd function joystick feature for my Kubota L4740, and after actually seeing it installed on one, I did not care for either the installation or the price. So I took a different path. This is not anything new here. I'm sure many of you have done a similar thing. I just thought you might be interested is seeing a picture of mine. Cause I know we all like pictures! It is much cleaner than the real thing. It maybe won't be quite as handy. But the price was right. I had most of the hoses and connectors form other projects. I just had to come up with the mounting bracket and a buy a couple quick disconnects. They are the top two connector in the picture that are mounted vertical instead of horizontal. (It was just easier that way) I plan to use this for a hyd. chute deflector on my front snowblower and I am adding a grapple to my rock bucket. Of course I still have the plumbing to run down the loader arms for the grapple, but one step at a time.
diy-3rd-function-joy-stick-img_0587.jpg  diy-3rd-function-joy-stick-img_0588.jpg
Couple of Achers is offline   Reply With Quote
Old 11-05-2009, 09:04 PM   #2 (permalink)
Super Member
kennyd's Avatar
Default Re: DIY - 3rd function joy stick - kind of
That looks fine, JD even offers a "kit" to do the very same thing. Nothing wrong with using the rear remotes since you already have them!
__________________
JD 4110HST
FEL, 60" MMM, 60" Rear Blade, Ballast Box, I-Match, #380 Snow Plow, FEL Forks, Goossen 3PH Chipper/Shredder, Markham LD-48 Grapple and much more "stuff"
JD 4x2 Turf Gator
Some of my projects/adventures are posted in my Picassa Web album.
kennyd is online now   Reply With Quote
Old 11-05-2009, 09:13 PM   #3 (permalink)
srs
Gold Member
Quote:
Originally Posted by Couple of Achers View Post
I just had to come up with the mounting bracket and a buy a couple quick disconnects. Of course I still have the plumbing to run down the loader arms for the grapple, but one step at a time.
Couple of Achers, Good job! I have a couple of questions for you if you don't mind. Where did you get the mounting bracket shown in the first pic? Can you please take a side photo of the mounting bracket? And finally, do you plan on running a solid or rubber line to the front of the tractor? I thank you in advance.
__________________
Stanley
srs is offline   Reply With Quote
Old 11-05-2009, 09:59 PM   #4 (permalink)
Quote:
I made the bracket out of some 3/16x2 flat stock. I first made a cardboard template until I got it just the way I wanted it. I had to cut some half moon shaped pieces out of the sides of the bracket to fit around the existing couplers. The two 5/16" bolts holes that hold the bracket on were already in the existing bracket, so I drilled corresponding holes in the new bracket. I used 3/8" rubber hoses. The whole size of 11/16" allows for the threads to go through the bracket. You can tighten the the joint as tight as you can and it still let's the hose turn, so it works as a pivot joint.
I cannot get any side pictures because the loader mounting bracket is in the way. I went out and took a couple of pictures of the back side of the bracket looking through the cab window. I think you can get a pretty good look at it. The sketch (no comments please) is what the bracket looks like. I think the key to it was making it out of cardboard first. Then start cutting the metal. Hope that helps.
diy-3rd-function-joy-stick-img_0589.jpg  diy-3rd-function-joy-stick-img_0590.jpg  diy-3rd-function-joy-stick-img_0591.jpg
Old 11-05-2009, 10:30 PM   #5 (permalink)
srs
Gold Member
Sir, thank you for the quick reply. Photos are perfect. Again great job! Will you run a solid or rubber line to the front?
__________________
Stanley
Old 11-05-2009, 10:45 PM   #6 (permalink)
You're welcome. I enjoy telling others about this. My wife is tired of hearing about it! I plan on running 3/8 rubber hose to the front of the loader arms. Probably won't have that factory finish look to it, but I have never messed around with the steel lines. I will have to manufacture another type of terminating bracket for up front. At that point I will be switching to 1/4" pioneer couplers and then from that point run 1/4" hoses to the grapple. All this will have to wait a bit. My first goal is to finish putting a hyd. cyl. on my snow blower chute. As much as I hate to think about it, snow is just around the corner here.
Old 11-05-2009, 10:52 PM   #7 (permalink)
srs
Gold Member
please keep everyone informed on your projects.
__________________
Stanley
Old 11-05-2009, 11:15 PM   #8 (permalink)
gumshu's Avatar
Nice work! Clean machine.
__________________
Bobcat CT235, Kubota BX23TLB & RTV900
gumshu is offline   Reply With Quote
Old 11-05-2009, 11:21 PM   #9 (permalink)
Quote:
Thanks. It should be clean. I just drove it off the lot today. Yes, I drove it home. I have the distinct advantage of being only 4 miles from the Kubota dealer. I guess that is an advatage. Depending on who you are talking to. Me or the wife.
diy-3rd-function-joy-stick-img_0576.jpg  diy-3rd-function-joy-stick-img_0579.jpg
Old 11-06-2009, 12:18 AM   #10 (permalink)
CowwFace's Avatar
Hey Couple of Achers,
Yeowzers that is one beatiful mochine! Did you have to add on the 3 rear remotes? My Kioti came with one set stock, and I can add a 2nd ... but off the lot with 3... that's like tractor porn!
We just had 41" of snow here in Colorado and I'm wishing for more already!
Phill
__________________
Kioti DK40SE HST
Our 2nd Amendment RIGHT comes from God and protects all the others!
CowwFace is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Terms of Use | Privacy Policy | Advertise | © 2009 TractorByNet.com
Safety Warning: TractorByNet.com does not review discussion forum posts for accuracy or safety. Please refer to manufacturer operator and safety manuals before operating tractors or equipment. Additionally, use caution and common sense when applying any advice you receive on TractorByNet.com, and seek professional advice before attempting professional tasks.
Page generated in 0.20136 seconds with 9 queries
