Go Back   TractorByNet.com > General Forums > Customization
Show Recent Threads:
24 Hours
Since My Last Visit
Reply
Thread Tools Display Modes
Old 11-18-2009, 01:54 PM   #1 (permalink)
Default Interchangable Bucket Hook System
Here are a few pics of my bucket hook solution, I mounted 4 pieces of 2.5" square tubing to the top edge of my bucket. I then got a thick wall length of 2" tubing the width of the bucket, I then made a couple of hook adapters. I used weld on 5/16 chain hooks, D-Rings and large tow hooks from the front of S10 Pickup for hooking straps to. I dimpled the 2" tubing in the center and directly in front of the cylinders for easy alignment. I drilled and taped set screws in everything so they fit tightly and don't rattle.
interchangable-bucket-hook-system-cimg4427.jpg  interchangable-bucket-hook-system-cimg4428.jpg  interchangable-bucket-hook-system-cimg4429.jpg  interchangable-bucket-hook-system-cimg4431.jpg
DonT-B7500 is offline   Reply With Quote
Old 11-18-2009, 07:15 PM   #2 (permalink)
srs
Gold Member
srs's Avatar
Default Re: Interchangable Bucket Hook System
Don, that is great! Very ingenious.
__________________
Stanley
srs is offline   Reply With Quote
Old 11-18-2009, 08:30 PM   #3 (permalink)
It is a neat solution, but I would wonder about the leverage effect on those large tow hooks being several inches away from the bucket? Probably won't be an issue for normal use. Good job, though!
__________________
Nothing could be finer than riding my 790 in South Carolina!!
2001 John Deere 790 4x4 with Model 70 FEL, 5ft International World Agritech bush hog, 5ft Wallberg BB, 5ft Frontier disc harrow, A&B Eagle Line 30" scoop pan, Leinbach PHD with 9" & 12" augers, Leinbach middlebuster, boom pole, custom built 3pt handi-hitch, Pat's Easy Change.
Nothing runs like a Deere, or smells like a John....
kebo is offline   Reply With Quote
Old 11-18-2009, 10:23 PM   #4 (permalink)
The little bar does fit but I don't plan on using it, I think you would have more of a chance of bending the bucket using only 2 of the supports. As for the leverage it would have been nicer if I could have mounted it below the lip of the bucket which would have lowered it about 1.5" but since my FEL capacity on my small machine is only about 1000# I'm sure I would max out the FEL before I break any hooks
Old 11-18-2009, 10:28 PM   #5 (permalink)
Elite Member
JB4310's Avatar
You might be on to something there.
I like it, I like anything interchangeable and universal, another good use of 2x2 hitch tubing. With something along those lines you could have an easily removable grapple.
JB.
__________________
JD 4310; E hydro, 300CX, 48 BH, 60" box, 72" rake, 72" rear blade, cast pallet forks, 61"HD & 73" high volume bucket.
FORD 1700; 2 WD, 2600 hrs.
JD 320; Hydra lift, 48" deck and 48" snow blade.
JB4310 is offline   Reply With Quote
Old 11-18-2009, 10:45 PM   #6 (permalink)
Yea, as soon as I saw what it looked like when I finished it I imagined how easy it would be to attach something like a "Thumb"
The Thumb
Old 01-23-2010, 03:30 PM   #7 (permalink)
gerard's Avatar
Not sure how well this shows but before I could weld this is how I made chain dogs for the top of my bucket. I also wanted to reinforce it since I'd seen too many overtorqued bucket tops that were bent and I didn't wnat to chance that. Just use a piece of 2 inch angle iron, bolted it to the top, and cut some notches with an angle grinder. Chain slips in either direction so you can life from front or back.
interchangable-bucket-hook-system-chain-dog-front-bucket.jpg  interchangable-bucket-hook-system-chain-dog-bucket-rear.jpg
__________________
Experience is something you get right after you need it!
Kubota L2500 DT w/ 5 foot FEL and Pat's easy change system
5ft box blade, 5ft bushhog, 6ft york rake w/ guage wheels, 7ft backblade w/skid shoes , post hole digger, 5 foot snowblower, dual axel 16 foot landscape trailer, 330 gal water tank, Ford 250 diesel, 6 wheel drive polaris ranger, 3 pt round bale spear
gerard is offline   Reply With Quote
Old 02-01-2010, 01:56 AM   #8 (permalink)
mjncad's Avatar
Pretty cool design Don. Here is one of my early welding projects.
Picasa Web Albums - Matt - John Deere 42...#
__________________
Measure it with a micrometer, mark it with chalk, cut it with a torch, beat to fit, paint to match, inspect it with a microscope.
Google finally fixed Picasa web albums problems I was having. Latest postings.
http://picasaweb.google.com/mjncad/HydraulicsUpgrades#
http://picasaweb.google.com/mjncad/ToolsPower#
mjncad is offline   Reply With Quote
Old 02-06-2010, 09:32 AM   #9 (permalink)
Quote:
The Thumb
How much $ for that thumb ?
spo307 is online now   Reply With Quote
Old 02-08-2010, 02:02 PM   #10 (permalink)
Gold Member
Quote:
http://www.greens-machine.com/id47.html
__________________
BX2350 w/ 60" mmm, FEL, Hyd frt blade, 5' KK landscape rake
Zick is offline   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Page generated in 0.06241 seconds with 9 queries
