Soot on my FEL
   / Soot on my FEL
Popcorn, good idea. Made me laugh anyway, can always use more laughs.
The neighbours would really think I had lost it then
Hey you could also use that Styrofoam "S's" that come in the packaging as well. There not much good for anything else plus I don't think it would require a pile of HP to move it around :D Don't worry about the neighbors. I'm here restoring this little bike and I can't even fit on it so imagine what my neighbors think of me :(
Got a photo of your tractor? Post it. Would love to see it.
   / Soot on my FEL #12
I didn't take this photo for this post but you can see I have done the same thing as you have. I also was disgusted with the soot on the FEL but I was also being fumigated while working around the front of the loader while attaching chains to concrete sections I was working with last summer. Works perfectly for me and no smell in the cab. All the broken up concrete parts on the ground were placed with the Kioti but I needed to borough a bigger helper to get the pieces up to the upper level.
   / Soot on my FEL
Great looking tractor. Love the cab and the exhaust ;). I almost had a Kioti last year but pricing, availability and the dealer it's self drove me to Kubota but I really like the Kioti line. Thanks for posting the pics.
   / Soot on my FEL #14
Why are you that concerned with the soot, its a tractor? I kind of like the smell of deisel exhaust, the smell of power, ok maybe not for hours though or when i need a deep clean breath of air while breathing hard and working.
Deon, what is all that junk on the back your using as a counter weight, just scrap you have welded togeather, and put pins on?
   / Soot on my FEL #15
Popcorn is more environmentally friendly, and I'm sure the birds and squirrels would like to clean up the leftover bits.
Where I lived before I figured part of my job was entertaining the neighbours, here I'm a bit secluded so can do lots of stupid things without much chance of anyone finding out.:D
The photo I attached was taken (with cell phone) about the end of March, just after I got the B3030, it has the old blower on it. We still have no snow and none shown in the forecast. Be good travelling weather over Christmas at least. I should put the new blower on, just for practice and to take some decent photos.
   / Soot on my FEL
Yep your right. It's a tractor but it's an orange tractor and I didn't want it turning into a black tractor without it being my choice. I operated heavy equipment for a living at one time logging up thousands of hours and believe me you do get sick of smelling diesel fumes after awhile.
If I liked the smell of diesel fumes as much as you do I would run the exhaust right into the cab :rolleyes:;):D
   / Soot on my FEL #17
I know what you mean about smelling diesel fumes.- I operate D9 and D10 dozers and they really will put out the black smoke under load.- Sometimes I just get so sick of smelling diesel.
:D:D Run the exhaust right into the cab.:D:D
   / Soot on my FEL #18
That's modern art. Don't you know anything!:D
   / Soot on my FEL #19
It's been bugging me since I bought the tractor last year. :mad:Every time I start the thing up the soot blows all over the FEL. Every time I use It I have to get the Spray Nine out and then clean it up.:mad: Some times it's hard to even get off so I needed to do something about it.
No where near the quality of 4shorts but here is my cheap way to fix the soot problem on my cabbed B3030. I cut off approximately 1 1/4" of the existing exhaust pipe. I bought a copper 1 1/4 inch street elbow 45 degree connector. The female end almost fit onto the exhaust pipe but was very snug. I grabbed the male end of the connector with visegrips and heated the female end as hot as I could get it using a propane torch. The heat expanded the female end and I was able to slip the connector onto the pipe and made sure it faced in a downward direction but away from the loader. I'll add high heat silver paint later. Cost of connector was just under $10 for one connector.
   / Soot on my FEL
Quality don't count with this stuff but I appreciate your kind words on my exhaust mod. The main goal is to keep that soot off the FEL. It worked great for me. I never had to clean the FEL once this winter and I'm happy about that. You did a nice job there. I'm sure it will make a Hugh improvement to your tractor.
