Page 1 of 5 1234 ... LastLast
Results 1 to 10 of 50
  1. #1
    Elite Member 4shorts's Avatar
    Join Date
    Jul 2008
    Posts
    3,245
    Bay Roberts, Newfoundland
    Kubota 5740,BX25D
    Default Soot on my FEL
    It's been bugging me since I bought the tractor last year. Every time I start the thing up the soot blows all over the FEL. Every time I use It I have to get the Spray Nine out and then clean it up. Some times it's hard to even get off so I needed to do something about it.
    I had planned on installing a stack. I purchased all the parts. Did the machining on them and thought that maybe it could be a little overkill on applying all of this so I decided to take the simple approach first. The main goal is to keep the soot off the FEL. My tractor is a cab model and it takes the fresh air from the top rear portion of the roof so I got some pipe and bent it back under the tractor pointing a little down so it's not on the ground or pointing towards the bottom of the tractor.
    During start ups it's great. I don't smell any fumes and there's no soot on the FEL. Snow will soon be here so It will get the real test then and if I find a problem I'll go back to my first idea of installing a stack. I don't think this would work on a tractor with out the cab because you may end up smelling the fumes. Here's how it looks.
    Attached Thumbnails Attached Thumbnails Soot on my FEL-exhaust-1-jpg   Soot on my FEL-exhaust-5-jpg   Soot on my FEL-exhaust-6-jpg   Soot on my FEL-exhaust-7-jpg
    ...Excellence is not a skill. It is an attitude...
    YouTube Video's: http://www.youtube.com/user/7863348?feature=guide
    2011 Kubota 5740/854 FEL/L2674 Blower/Artic Angle blade with 3rd function set up,Rain Tracker Wiper system, custom built vertical exhaust,Grammer Air Ride Seat and other custom stuff
    2013 Kubota BX25D with many mods
    Kubota ZTR ZG 222 Z
    Custom Toyota Fork Lift
  2. #2
    Silver Member Midsouth's Avatar
    Join Date
    Feb 2008
    Posts
    156
    Okolona,MS
    Mahindra 2555
    Default Re: Soot on my FEL
    Looks good to me. I don't think snow will be a problem but that's just my thinking. Don't get much of the stuff where i live.
  3. #3
    Join Date
    May 2008
    Posts
    118
    SE Michigan
    Kioti DK35SE
    MIne is the same way, drives me crazy! I just haven't been ambicious enough to fix it. Good idea!
    Dan
    2008 Kioti DK35SE HST
    KL351 FEL, 6' York rake, 6' Blade
    1983 Ingersol 448 with 64" mower deck.
    MS250C Stihl, 27 ton splittah w/ Honda engine
  4. #4
    Platinum Member brandoro's Avatar
    Join Date
    Jan 2008
    Posts
    657
    Central Saskatchewan
    Kubota B3030 HSDC
    I put an angled extension on the B7610 I had before partly to keep the exhaust off the loader arm but also because I was using it a lot as a wheel barrow, loading the bucket with pavers and retaining wall blocks for landscaping I was doing. I would have to shut the engine off, even if I wanted it to warm up, while I was loading because it would blow exhaust in my face. The exhaust on the B 3030 is turned down more but does still get soot on the loader arm. The exhaust is a different size so the adaptor I had for the B7610 doesn't fit. It might not work anyway given the different angle.
    Your adaptor looks good, since it has its own support it should be okay in the snow. Nice bender, by the way. Makes it easier to turn ideas into reality.
    Rod.
    B3030HSDC, LA403 FEL, B2782A front blower, B5320 ballast box, Landpride-BH, RFM, tiller, FM2060 flail, GS1572 grader/scraper, BX42 chipper, PTO generator, homebuilt splitter and 3pt carry all.
  5. #5
    Join Date
    Jul 2008
    Posts
    3,245
    Kubota 5740,BX25D
    I got a little over 20 hours on the tractor this past week plowing snow and I'm very pleased with the extension. No fumes in the cab and no soot on the FEL. I just got tired of cleaning the black soot off this tractor. I'm a happy camper now.
    Kubota ZTR ZG 222 Z
  6. #6
    Elite Member
    Join Date
    Nov 2005
    Posts
    3,097
    Seems like a good way to smoke out bugs from row crops.
    Maybe you don't "garden" (verb) ?
  7. #7
    Silver Member Low Bucket's Avatar
    Join Date
    Nov 2009
    Posts
    222
    Mountains of West Virginia
    John Deere 110 TLB-John Deere X595- John Deere ATV
    Nice work 4shorts!- I've been reading up on all your projects and you sure do great work.- I wish you lived close to me.( like next door or something)
    Had the thought crossed your mind of running the exhaust up the top and using stainless exhaust ?
    Your tractor looks great!
  8. #8
    Join Date
    Jan 2008
    Posts
    657
    Kubota B3030 HSDC
    Quote Originally Posted by 4shorts View Post
    Brag, brag, brag. Oh, sorry. It's just that we still have NO snow. The tractor hasn't been outside for a few days now, partly because it is too cold to be out for no good reason but mostly because there is no reason at all to take it out. I still have a shiny new front mount snow blower that I haven't tried out yet, don't even know if it will get soot on it.
    Rod.
  9. #9
    Join Date
    Jul 2008
    Posts
    3,245
    Kubota 5740,BX25D
    Quote Originally Posted by Reg View Post
    Never thought of that. I was think by pointing the exhaust down it would melt the snow and that way I wouldn't have to pow it
    Quote Originally Posted by Low Bucket View Post
    Thanks Low Bucket. Glad you like my work. In my business that's what counts. Right now I'm restoring a 1969 Honda Z50 Mini Trail. I'm actually painting the tank right now and waiting between coats. I thought about many different types of exhaust systems and like I said at the beginning of the thread, Sometimes simple is best and so far this is working out very well for me. Good idea you had as well. Thanks!
    [QUOTE=brandoro;1826955]Brag, brag, brag. Oh, sorry. It's just that we still have NO snow. The tractor hasn't been outside for a few days now, partly because it is too cold to be out for no good reason but mostly because there is no reason at all to take it out. I still have a shiny new front mount snow blower that I haven't tried out yet, don't even know if it will get soot on it.[/QUOTET
    Snow this time of the year around these parts can be very little. that being said last week we got more snow in one storm that we usually get for the full month. I would use the plow to push it then put the bucket on and hall it away. Snowing again today. I feel your pain though. Nothing worst than having your setup and not have a reason to use it. Pop a bunch of popcorn and go out and blow it around
    Kubota ZTR ZG 222 Z
  10. #10
    Join Date
    Jan 2008
    Posts
    657
    Kubota B3030 HSDC
    [COLOR="Blue"]
    Popcorn, good idea. Made me laugh anyway, can always use more laughs.
    The neighbours would really think I had lost it then
    Rod.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
