Page 1 of 2 12 LastLast
Results 1 to 10 of 11
  1. #1
    Join Date
    Oct 2005
    Posts
    196
    Conn
    Default Frame mount Backhoe and 3pt hitch
    I am wondering if any one has seen a solution to keeping the 3pt hitch arms on with the frame mount back hoe? My back hoe uses the same attachment points as the lower arms.
    Thanks Bob
    Branson 4720 TLB with Thumb/John Deer 310/Mcormick Deering W-4
  2. #2
    Super Member RickB's Avatar
    Join Date
    Sep 2000
    Posts
    9,431
    Lincoln County, NC need new avatar!
    Just a Scag
    Default Re: Frame mount Backhoe and 3pt hitch
    Not all brands are that inconvenient.
    Spring is the season of optimism.
  3. #3
    Member FarmerGene's Avatar
    Join Date
    Feb 2010
    Posts
    36
    Case D29
    Quote Originally Posted by BobQ View Post
    Thanks Bob
    On mine I just bring them into the inter most position an pin em there.
  4. #4
    Veteran Member magicheater's Avatar
    Join Date
    Jul 2009
    Posts
    1,668
    central Wisconsin
    Kubota B7800, B26 TLB
    I am wondering if any one has seen a solution to keeping the 3pt hitch arms on with the frame mount back hoe? My back hoe uses the same attachment points as the lower arms.Thanks Bob
    My Bush Hog unit requires the same thing. If I think of anything clever I'll let you know but I am afraid in this case you can't have your cake and eat it too.
    Working to increase the scope of the small tractor experience, one quick attach at a time.
  5. #5
    Platinum Member tessiers's Avatar
    Join Date
    Sep 2007
    Posts
    728
    Central Maine
    05' JD 790 - 53' Ford NAA - 70' Massey Fergusen 135 diesel - 67' John Deere 3020 deisel - 77' John Deere 2130 - 1950 John Deere MC
    why do you need the lower arms and the backhoe at the same time? seems like a moot point to me, unless I'm missing something.
    check us out at www.tessiersfarm.com
  6. #6
    Silver Member chevy292's Avatar
    Join Date
    Nov 2009
    Posts
    109
    Ma.
    Kioti DK35 TLB
    Quote Originally Posted by tessiers View Post
    It's just one more step to change implements. Fortunately on my kioti the arms don't have to come off.
    DK35 TLB. 6' Box Blade, 60" flail mower
    1963ish JD 2010 TLB
  7. #7
    Join Date
    Oct 2005
    Posts
    196
    Conn
    Yup,
    Thats just it, it takes me longer to put the arms on and off than the hoe, so basically it's just a time saver.
    Can anyone add a pick of how theirs allows both at the same time? I have a few ideas but nothing final yet.
    Thanks Bob
  8. #8
    Platinum Member FredH's Avatar
    Join Date
    Jul 2007
    Posts
    845
    Ruch , Oregon
    N.H. TC-30
    Do You have a picture of what you are trying to accomplish / or dealing with ?
    My TC30 has a sub-frame mounted so its not required of me to take off the 3 point arms , just have to loosen up the turnbuckles so they can swing far enough inside rear frame of backhoe for clearance .
    Why I ask about a picture is that although some , like myself and others , may not have that problem with their set-up , by seeing the problem they may be able to come up with a solution , rather than trying to visualize it .
    Just a Thought .
    Fred H.
  9. #9
    Veteran Member CCWKen's Avatar
    Join Date
    Mar 2005
    Posts
    1,195
    South Texas, USA
    Ford-3910, JD-420C, Kenbota-Custom, IH-2606
    Ditto what Fred said.
    I can pull three pins and the lift arm, swing arm and sway is off. Duplicate that for the other side. That takes what, a minute?
  10. #10
    Super Member dfkrug's Avatar
    Join Date
    Feb 2004
    Posts
    5,661
    NorCal
    05 Kioti CK30HST w/ Prairie Dog backhoe
    I am not sure how your Branson subframe is made, but maybe you can
    make a different rear mount that does not interfere with the 3-pt hitch
    lower are pivots. Maybe that is is impractical.
    Early kubota subframes from Woods did it that way, which is very
    inconvenient. It was a lot of work to remove the rear subframe bracket
    before you could even put the 3-pt arms back on.
    Here is a photo of a subframe I made that avoided any interference with
    the 3-pt arms, which I leave on (but folded up) while the hoe is on.
    Attached Thumbnails Attached Thumbnails Frame mount Backhoe and 3pt hitch-ck30_sub_r_2-jpg
Similar Threads
  1. Davis Model 185 Backhoe conversion to 3pt
    By waggy5 in forum Hydraulics
    Last Post: 06-21-2012, 10:08 PM
  2. Backhoe 3pt vs. frame mount backhoe
    By twomanytractors in forum Attachments
    Last Post: 01-14-2010, 08:43 PM
  3. Backhoe 3pt Backhoe...Do I need to lift it?
    By Bl8tant in forum Attachments
    Last Post: 06-11-2008, 05:27 PM
  4. Backhoe How Many people have 3pt hitch backhoe?
    By alaskakubota in forum Attachments
    Last Post: 04-21-2008, 01:07 PM
  5. 3-Point Hitch 2910 NH with Arps 728 3pt backhoe
    By okgat in forum New Holland Owning/Operating
    Last Post: 03-22-2007, 11:50 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
