06-22-2010, 10:39 AM
#1 (permalink)
| | Member
| wood (No weld) tractor mods Here are some pics of wooden tractor modifications. Bucket forks, chainsaw and chain racks and a cant hook holder. So far everything is working as required. Scrap 2x4, 3/4" plywood, construction adhesive and drywall screws - cheap. |
06-22-2010, 10:56 AM
#2 (permalink)
| | Platinum Member
| Re: wood (No weld) tractor mods when i was a kid, the family had a camp on a dirt road. the guy who maintained it had an old grader setup with a wood edge. the running joke was that we the road was good, he must have put a new 2x6 on. |
06-22-2010, 12:17 PM
#3 (permalink)
| | Silver Member
| Re: wood (No weld) tractor mods It's good to learn to utilize what you have on hand, that wood might not be your first choice but it gets the job done.
Modify, adjust and improvise....a country boy can survive. |
06-22-2010, 04:16 PM
#4 (permalink)
| | Silver Member
| Re: wood (No weld) tractor mods BRILLIANT! Creativity at its finest. May I copy some ideas?
As an aside is that saw a Husky? It looks like it. Ever have an issue with the gas leaking around the cap? All of sudden, second saw, and I am leaking gas. |
06-23-2010, 04:04 PM
#6 (permalink)
| | Silver Member
| Re: wood (No weld) tractor mods Quote:
Originally Posted by LBrown59 Here are some of my Woodies. | Sounds kinda personal to me. |
06-23-2010, 06:59 PM
#7 (permalink)
| | Veteran Member
| Re: wood (No weld) tractor mods LBrown59, really like the back hoe mod,  simple but effective.
__________________ Working to increase the scope of the small tractor experience, one quick attach at a time. |
06-24-2010, 10:22 AM
#8 (permalink)
| | Super Star Member
Join Date: Oct 2004 Location: First organized permanent settlement in the northwest territory
Originally Posted by magicheater LBrown59, really like the back hoe mod,  simple but effective. | Thanks.
__________________ Tractors 2003 Kubota BX1500 / 2004 Kubota Bx23 / 2005 Kubota BX1500. Attachments 60'' Front Blade/48'' Rear Tiller/FEL/Back Hoe /
60'' MMM/Clamp on Forks/48'' MMM South of Canton Ohio L .B |
06-24-2010, 10:01 PM
#9 (permalink)
| | Veteran Member
| Re: wood (No weld) tractor mods I am with you on the wood mods. Check out my post in the "attachments" section under "sun-shade". Wood has a much better strength/weight ratio than steel or even aluminum, which is good for keeping center of gravity down on top-mounted attachments, and ease of mounting. I also made some wood fork extensions, which I use quite often to lift the cap on and off my pickup with the loader. I aint a bad welder, and have made my share of steel attachments, but wood definitely has a place. |
06-25-2010, 02:10 AM
#10 (permalink)
| | Elite Member
| Re: wood (No weld) tractor mods I can hardly wait to see these show up on Chinese made tractors and implements. They'll paint them to look like steel.  |
